Question about In Office Equipment & Supplies
How to make copy contras and brightness in service mode
How to fix f18 fault
The f18 code that pops up in these models is related to the "contra-rotating" mode unique to this line. This mode is very tough on the gears and drum and they end up binding. The only "real" fix is a new drum assembly, which dyson has run out of for service parts. You can run the washer without using the contra-rotate mode and the unit will not act up. Other than replacing a no longer available part, some owners have found that by washing some oil-soaked articles (such as shop rags or towels drenched in motor oil), the offending parts binding issue can be lubricated away for quite some time. When the f18 error returns, they just wash some more oil into the problem area to make it disappear again.
Check out the facebook page for more info than you will need.
93867830652471/">Facebook logo
Jan 04, 2015 | Dyson Washing Machines
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
How to make video colored?
Hi there
Try to adjust the brightness and contras in the PICTURE menu
good luck
Mar 11, 2012 | Sharp LC-20S4 20 in. EDTV-Ready LCD...
Lost my user's guide need to change make copies darker
May I know the model # of your machine?
Some of brother machine have the copy options where you can change the brightness, contrast and color of the document that you are copying.
For example for MFC-240:
You can change the brightness contrast by pressing copy mode. Then load the document in the feeder, press copy option so that it will show the option to change the brightness, contrast and color. Just press the arrow key to select the brightness then hit ok/menu. then press arrow key to have it lighter/darker..
Hope this helps.
Mar 29, 2011 | Brother Office Equipment & Supplies
What is contra entry? how it is done?
Contra mean to contradict or place an opposite.
A contra entry is issued to the books by placing a negative amount in the dr column.
Mar 04, 2011 | Computers & Internet
How to unlock the code of contra
The Contra Code, also known as the Konami Code, is used in most konami games, and is Up,up,down,down,left,right,left,right,B,A, then start or select, depending on what game it is. for Contra, It would be start
Jul 06, 2010 | Nokia E51 Smartphone
Picture is not bright
Try to re settings your Unit... go to settings then choose color setting then click brightness control or the contras control.
Jan 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
1701FP display problem
Try to do the factory reset. It is on the pop up main menu on the screen by pressing the screen button.
Thank you,
Jan 12, 2008 | Dell UltraSharp 1701FP 17" LCD Monitor
Top In Office Equipment & Supplies Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
