Question about Home
My Capello alarm clock Model CA-15 does not stay on Hawaiian time. How do I keep it on Hawaiian time. I turned off Daylight Savings time already.
SOURCE: Daylight saving time issues
I picked this up from the Emerson Website Read below before going to the link. Try thi link: and poke around the website http://www.fox-international.com/emerson/ Important Notice About Daylight Saving Time (DST) and Emerson SmartSet® Clocks and Clock Radios Congress recently passed a new Energy Bill which includes a provision to extend Daylight Savings Time. At the beginning of 2007, Daylight Savings time will begin on the second Sunday in March and end on the first Sunday in November. Because of this change your SmartSet® Clock or Clock Radio will need to be updated. In order to set your unit we will need the following information from you: 1. Model Number You can find your model number on the back or bottom of your unit. (Click here for an example) 2. Serial Number You can find your serial number on the back or bottom of your unit. (Click here for an example) Based on this information we can identify which setting is necessary to adjust your unit for compliance with day light savings. There are three possible groups your SmartSet® Clock or Clock Radio could fall into: Group One changes the time zone to a previous time zone. Group Two adjusts for the spring and fall settings. Group Three is already set for 2007 daylight savings compliance. Group identification begins with your serial number. The first three to four digits of the serial number represent the year and month of manufacture. (If your serial number begins with 0607, that would indicate July 2006, 506 would indicate June 2005.) Models manufactured before January 2006 (serial number 506, 512, etc.) will follow Group One settings. Models manufactured between January 2006 and July 2006 (serial number 0601, 0603, etc.) will follow Group Two settings. Models manufactured after July 2006 (serial numbers beginning with 0608) are Group Three and do not require any changes. If you believe you have a Group One model, please click here. If you believe you have a Group Two model, please click here. If you cannot determine which Group your model may be in, please call us at 1-800-526-7521.
Posted on Mar 11, 2007
SOURCE: Model CKS2237 Daylight Savings needs to be reprogramed
I have the same model, and I haven't found any sites that give a permanent solution. I did find a workaround for this model, which seems to fall in the "Group One" category on the following site. It is at least more of a one-touch solution (4x/yr) than manually moving the time forward/backward 4x/yr.
Posted on Mar 08, 2008
dodgecharger
  • 254 Answers
SOURCE: setting the clock/time
There should be a menu button on the remote which will get you into the various advanced programming functions. Many/most of the late VCRs cannot be programmed, time set with the buttons on the VCR itself.
Posted on Mar 12, 2008
SOURCE: Emerson Research SmartSet Clock Radio
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
Posted on Aug 10, 2008
SOURCE: Day light Savings time problem
Hi ... I have the same problem ... I found this link but I haven't tried it out yet ...
http://www.emersonradio.com/dst_g2.htm
Posted on Oct 28, 2008
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Daylight saving time auto change over
call 18006954820 they will walk you through
Nov 02, 2007 | Timex T276B Clock Radio
Help daylight savings time is not here yet
I am going to try changing to time zone 7 (Hawaiian Time). Hawaii does not observe DST so this should turn the clock into a regular clock that ignores DST and you need to set yourself twice a year.
Oct 30, 2007 | Emerson SmartSet CKS1850 Clock Radio
Emerson Smartset Radio Model CKS2288
The Daylight Saving dates appear to be hard-coded per the manual:
Start of Daylight Saving Time:
At 1:59.59 AM on the first Sunday in April, the clock will automatically advance to 3:00 AM.
End of Daylight Saving Time:
At 2:59.59 AM on the last Sunday in October, the clock will automatically reset to 2:00 AM.
So the easiest thing to do is to change your time zone up or down one for the period between the new DST date and the old -- or you can buy a new SmartSet for about $15. The newer ones do not have the same problem.
Oct 29, 2007 | Emerson Smartset Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Mar 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
Timex T301B
Petewete,
Here is the manual.
http://www.timexaudio.com/pdf/T301IBOnline57204_83.pdf
Frank081541,
You can't adjust the Daylight Savings Time. I called Timex and they confirmed this.
Mar 06, 2007 | Timex Auto-Set Dual Alarm Digital Clock...
Home Logo
1,115 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
