Question about Briggs Garden
I have a Snapper, Briggs and Stratton 550EX, I was told at Walmart that I needed to put the oil in that came with mower and also put a small container of pro 40 oil in the gasoline also. Why both
  • 1,057 Answers
If it is a 2 cycle engine you would not need both, but if it has oil in the crankcase you would put oil into the crankcase and the other would not be needed. However, I am like you it does not make sense if the engine is a 2 cycle engine. If it is a regular engine you would not need oil in the gas. Maybe you should go back and ask Walmart to clarify what they are talking about.
Posted on Apr 22, 2017
Black small hose is loose on briggs&stratton 550ex mower engine
fuel should never be coming out of the air filter. do you mean the pipe that goes from the engine to the air filter housing? if so thats the crankcase breather pipe and you shouldnt be getting fuel there either. if you have fuel coming out of the air filter housing then you carb is probably flooding and will need stripping and the needle vale and foat looking at
Jun 21, 2014 | Briggs & Stratton Lawn Mower Air Filter...
Where is the oil drain plug on a briggs and stratton 550ex 140cc push mower
on the opposite side of the engine block of the carburator it has 2 ears and screws out
Apr 05, 2014 | Briggs & Stratton Garden
I need to find free diagram for linkage hookup on a 10 HP Briggs & Stratton Snapper riding lawnmower
I would go to mytractorforum.com, click on the word 'forum' just to the right of the tractor wheel, and scroll down to the small engines and repair section. Inside 'stickies' is a directory of B&S service manuals.
Apr 14, 2013 | Snapper Garden
HOW TO CHANGE OIL IN TROY BILT 550EX 140CC PUSH MOWER
http://diymaster.siterubix.com/change-oil-push-mower
Apr 02, 2013 | Briggs & Stratton Garden
Need to adjust rubber drive clutch on 30 inch snapper mower
there are small metal beads on the cable near the pedal you move to the other side of the pedal if the friction wheel is warn you will need to replace it only 3 nuts hold it on just flip the mower up on the rear bar and take it off no fancy tools needed
Jun 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
What 2-stroke mix for a Snapper mower (Briggs & Stratton 6.5 HP)?
USE A 32:1 MIX. THE MORE THE RATIO OIL TO GAS MIX RATIO THE MORE COOLER AND LONGER LASTING THE ENGINE WILL BE. 40:1 IS FOR FULL OUT TROTTLE CHAIN SAWS ECT.
Mar 13, 2012 | Snapper Garden
I AM REPAIRING A SNAPPER COMET 30 B/S 7HP RIDING MOWER: (APX. 1966-1969) 1) TIRE PRESSURE? FRONT-410/350-4, REAR-16 X 6.50-8 2) WHICH FRONT BELT PULLEY DO I LOOSEN TO ADJUST OR REPLACE BELT? 3) REAR AXLE...
Chances are you wont get a manual, just lube it up.tires probably 12 to 15 lbs .the belt is mecanicly tensioned so there is no adjustment. Check the idler pully tensoner and ingage lever for proper travel and tention
Jun 03, 2010 | Briggs & Stratton Garden
I have a Snapper Briggs & Stratton lawn mower Model Series 126T00 and for some reason it will not start.I drained the gas tank ,put fresh gas in it. I did a caburetor kit and it still will not start....
How about the key way? Its the timing of the motor. Its under the pull rope and the wheel under the pull rope. Might be cut or broke in half.
Mar 21, 2010 | Garden
Garden Logo
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
