Question about Brother Network Ready All-In-One InkJet Printer
MFC425CN will not scan through network
Hi, I have an MFC425CN. It will scan fine using the USB port but not through the network. Everything else works well through the network connection which is what we reall need. We use Paper Port for the scanning program. Please can you help. Thanks. Chris
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    What OS are you running?
  • 630 Answers
    Habit-Forming:
  • 96 Answers
In my experience with printer all in ones they never scan over the network. So your best bet it to just hook the printer to a pc scan it and then you can share it on the network.
Posted on Jul 24, 2009
The dlink dir 600 wireless router seems to provide me intermittent connection i tried checking the cable connections from modem to router and everything is fine. i tried to ping the DG 192.168.0.1 but i...
If you have two routers in the network (the cable router and your own router), make sure you only use one dhcp. If you use two, it make thing more complicated. To test the router you should properly disconnect other connections that is not being tested. Finally try to reset the router to factory setting. If you are using USB Network device, make sure the USB port provide enough power to power-on the device. Double check the key....Good luck
Jun 21, 2017 | D-Link DIR-600 Router
Dear Sirs/Madams, I have a Muratec MFX-1930 network multimachine (printer,scanner,copier,fax). Everything is working fine i can print, fax, copy and scan. My problem is the scanner scans to internal...
Unless your machine is connected via ethernet cable.( NOT USB.!!) you will not be able to scan directly to a Network folder.
Anotherwords..you can scan to a Network folder if its an RJ45 cable but NOT if your using USB.
If you are using ethernet the machine should have come with the appropriate software...if you have lost it you can get it at www.muratec.com .
**If you are using USB...installing the Network software will NOT make it scan to folder.
Apr 01, 2011 | Muratec Copier
When I try to scan something it tells me the usb is not connected but it is. Use to work fine and now won't scan.
check different usb ports. and check usb ports by Pendrive. if pendrive works fine then use different cable. best of luck
Jan 17, 2011 | HP Photosmart C4240 All-In-One InkJet...
Can the Sharp al1642cs work with just usb connection?
I've been using my AL1642CS connected by USB to my Windows XP Pro desktop for about a year now - very reliably - both for printing and for scanning. I love the duplex print feature, so much easier on the trees!
I've also printed to it through the USB port on my network router - but then I can't use it for scanning since Microsoft never enabled network scanning - only network printing!
Dec 06, 2010 | Sharp AL-1642CS Copier
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
Scx-4216 network scan not working
The solution is using the software smarthur3 that come with the CD, then download smarthur4 on both server and client computer......
smarthur3 will run as network, and use smarthur4 to scan.
on client in smarthur4, under scan , then setting select the network name.
everything work now....
smarthur4 even have pdf format.
let me know if you still have problem.
Mar 06, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Usb 2.0 ports not working on my emachines T3504
You may need to uninstall your current usb's and let Windows redetect them.
click on START, SETTINGS, CONTROL PANEL, SYSTEM. Click on tab HARDWARE, click on DEVICE MANAGER. Scroll down to UNIVERSAL SERIAL BUS CONTROLLER. Delete everything there. Click on ACTION, SCAN FOR HARDWARE CHANGES. It should redetect and you should be good.
Jul 24, 2008 | E-Machines eMachines Desktop PC
USB ports suddenly not functioning
hi, see if you have installed any new devices/hardware to see if its conflicting, often grafics cards conflict usb devices, also just check that in the setup(when you boot up)that the usb ports have not been disabled or usb keyboard support hasn't been enabled/disabled. good luck!!
Apr 01, 2008 | EliteGroup nForce3-A Motherboard
Scan To Button is not working over Network PCs
I uninstalled the Norton Antivirus from my PC. Now it is working fine.
Jan 13, 2008 | HP LaserJet 3055 All-In-One Printer
Print Okay , PhotoCopy Okay, Scanner Problem
If you are still having problems and are running windows vista what I had to do was go to this web site http://www.samsung.com/me/products/printer/multifunction/scx_4100.asp?page=Specifications and click on drivers in the box at the top and there is a separate scanner driver that has to be installed for it o work it has fixed my problem..
Nov 14, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Brother Network Ready All-In-One InkJet Printer Logo
110 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
