Question about Garden
New troybilt bronco, the accelerator is so hard to push, hard to relax and just cut my big yard, will it loosen up? it takes all my leg strength to give it the gas... #woman who loves to cut the lawn
#1 Taper
  • 1041 Answers
SOURCE: Need help with belt on Troybilt self propelled push mower
Try removing the pulley in order to put the belt back on.
Jim
Posted on May 30, 2009
#1 Taper
  • 1041 Answers
SOURCE: My Yard Man push gas-powered lawn mower dies out
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 26, 2009
  • 62 Answers
SOURCE: Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Posted on Sep 07, 2009
rutherford_m
  • 63 Answers
SOURCE: car is cutting out
What you are describing is the inability of the engine to take a wider throttle setting. I would clean the MAF (Mass Air Flow) sensor first to see if that clears up the issue. The MAF senses the amount of air coming into the air intake, if it is dirty or damaged it will not send the correct signal to the ECM and in turn the proper fuel mixture will not be delivered to the engine cylinders. Cleaning a MAF is fairly simple, but requires some caution. The MAF is rather fragile and should only be cleaned with MAF Sensor Cleaner. Simply follow the instructions on the product. The MAF is normally located on the air intake system directly behind the air filter box.
Posted on Apr 30, 2010
rycgl
  • 1545 Answers
SOURCE: My yard machines push lawn
Try removing the brass bolt that holds the float bowl on the carburetor and cleaning ALL the tiny holes in it. Use no metal objects on it as it is also the main jet of the carburetor. Carb/Choke Cleaner aerosol spray works well here. Pay close attention to real small holes near the top in the unthreaded portion of the bolt. Remember, no scraping with metal and no metal wires thru it.
Posted on May 10, 2011
My 96 ford bronco runs rough on acceleration,idles fine. Runs good under light acceleration but if hit the gas hard runs bad and pops. Changed fuel filter no change.what next?
givit a tune--new distributer cap--new plugs and cables--------also have air intake cleaned plus idle control--use a nonchlorinatd solvent sold a napa etc
Jul 22, 2014 | 1996 Ford Bronco
How do i remove a troybilt bronco riding mower rear wheel?
The caps are held on by a washer and they usually will snap off with a long screw driver
May 08, 2014 | Troy Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
I have a Manfrotto 685B monopod that I have had for about a year. Recently I noticed that it has gotten very hard to extend or retract the leg sections of pod. I looks like there is a wax substance on top...
If it was second-hand or pre-owned, the previous owner may have applied some form of lubricant to it. From a look at the images on the Net, it appears that the upper sections are adjusted by twist grips. If this is so, just unscrew them and separate the leg sections carefully, after which they can be cleaned. There may be a bevelled collar within, to grip the section - be careful with it.
The bottom section seems to have a standard lever lock. There should be a couple of screws holding this to the middle section - loosen these, then slide the leg portion out and clean it as well. When re-assembling this part DO NOT over tighten the screws - just enough to prevent the locking collar from moving.
Apr 08, 2017 | Bogen Communication Bogen / Manfrotto 685B...
Transmission stuck in overdrive on a 1988 Ford Bronco II 2.9L V-6 with a 5-Speed on the floor.
Sounds like a gear lockup, two choices take transmission out and find someone to rebuild it or would have to go to salvage yard and find another one. a new rebuild is approx 1,300.00 or salvage yard is approx 300.00..
Dec 12, 2010 | 1988 Ford Bronco II
I have a 1986 Bronco II with 4 wheel drive and automatic trans. 185,000 miles when it warms up it will stutter and lose power when you try to accelerate. I am able to baby it up slowly to a faster speed...
Try checking the spark plugs gap and ignition wires and cap and rotor sounds like a spark delivery problem to big of an air gap at cap/rotor or plugs what size engine? Carburetor or fuel injected? It makes a big difference
Dec 29, 2017 | 1986 Ford Bronco II
2006 r1200rt engine cuts out during hard. bike works fine during
Hi..my name is Keith..and most new motorcycles has a thing called a "Rev Limiter"...and it if you push or rev it hard..it will make all kinds of popping and crackin noise and you will lose horse power..i dont know how hard you are trying to push your motorcycle..i hope this helps you
Jun 29, 2009 | 2007 BMW R 1200 RT
Jim
May 29, 2009 | Troy Garden
Remove water pump
sometimes those bolts are hard to get off. just keep trying and be sure not to strip them. put a big screwdriver or a pry bar between two of the bolts as you loosen one. then do the same all the way around the fan. and be sure to take out the radiator shroud to have more clearance
Jan 06, 2009 | 1989 Ford Bronco
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
