Question about Crock Pots & Slow Cookers
How to dissemble the cooker top lid on the power pressure cooker xl
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
Http://www.powerpressurecooker.com/downloads/PCTRI6_IB_TP_ENG_V10_151214.pdf&ved=0ahUKEwjuz6et7rjTAhXLzIMKHfPBAO4QFggaMAA&usg=AFQjCNG6n88GNgvTDmvEc5phOkRnLPeiuw&sig2=x8o3lA3UBXNnlSA1t_YD2g
Posted on Apr 22, 2017
Pin fell out of the power pressure cooker xl....steam coming out of handle...how do I put it back in?
There are two parts to the 'float valve' pin which has fallen out.
The pin itself pushes back in from the underside of the pan lid,
BUT,
there should be a clear silicone grommet or washer, which slides over the pin from the outside. This is what holds the 'float valve' pin in place & stops it falling into the pan in use.
If you've lost the original grommet in the washing-up, there might be a spare which came in the original box with the pan.
If not, you can order the replacements from the manufacturer or on eBay.
(https://www.ebay.com/itm/Float-Valve-Sealer-Power-Universal-Pressure-Cooker-XL-YBD60100-PPC780-PPC770-New/302469900126?hash=item466c9c675e:g:A7QAAOSwkRpZpszq)
Best of luck.
Mar 14, 2018 | Crock Pots & Slow Cookers
My power XL pressure cooker will power up, but you can't set the time for food; the display stays on zeros What can I do?
This is an indication that the keypad is not working and that could mean the controller is bad. If it is out of warranty, it is time to replace it Customer Service Power Pressure Cooker XL
Feb 18, 2018 | Crock Pots & Slow Cookers
Pressurer cooker XL rubber washer came out of lid with the plug
One writer from essay universe.org gave me a riddle. I'm thinking about answer already a week. Who can give me advice? - What is so delicate that even saying its name will break it?
Feb 13, 2018 | Crock Pots & Slow Cookers
First time user, steam valve on my xl power pressure cooker sits loosely in the sealed position. Wonder if it is broken. It doesn't turn easily to open. haven't started cooking yet. Can you help me?
the valve is a safety valve to release pressure that gets too high
the action is by the weight of the valve itself sitting over a small opening
as pressure is generated by resistance to flow, that small opening area has to have enough pressure ( psi /surface area) to overcome the resistance to flow ( the weight of the valve body)
when that happens there is a brief loss of pressure and then the valve reseats and the cycle begins again
simple ,effective and safe
to relieve the pressure before opening the lid , remove the valve
Apr 24, 2017 | Crock Pots & Slow Cookers
How do I open the stuck lid on my Power Pressure Cooker?
The cooling food has caused a vacuum making it worse. If you heat the food very gently as not to burn the contents, the lid should open once it is hot. Release any pressure and try and open it again.
Jan 01, 2016 | Crock Pots & Slow Cookers
I can't take the lid off the pressure cooker, it's as though the locking mechanism doesn't has not disengaged
pressure use a 1/4 turn of the top against the bottom to undo the locks after the pressure in the pot has been released by removing the safety valve
any pressure at all in the pot effectively stops the lid from turning
Aug 08, 2015 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
The recalled 8 qt ultrex ll pressure cooker model # 11302c will the lid come off on its own or does it just not lock while under pressure?
Halt, do not use this pressure cook. The lid is suspose to lock. This means the lid become a dangerous fly object if it came off under pressure, plus extremely hot boiling water and the contents of the pressure cooker. Beside possible dying from the lid, and if one survives the flying lid, one will be will scalded by the contents of the pressure cooker. Another pressure cooker manufactured in China. Sorry, GB...stewbison
Sep 12, 2011 | Ultrex 2-in-1 (9qt) 8-Quart
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Crock Pots & Slow Cookers Logo
222 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
