Question about The Computers & Internet
Can't get the housing cap off my dreamedl 4200
How do I fix a Dremel 4200
I just came across this problem and could not find help online. Dremel wants me to send it to them. Their turn around time is 3 days but that doesn't count the 4 day ship to time nor the 4 day day ship back time.
I cut it off with another super cheap dremel type tool. I would have used a sander or bench grinder if necessary.
After I grinder down to just see the threads I put a flat head screwdriver in and pried it loose and then it twisted off easily.
I then realized what cause it. The plastic housing threads had slightly melted to the metal threads. Dremel bits get hot! The heat works it way to the shafts which in turn works it's way into the plastic.
The dremel can be used without this housing if you completely destroy it. I'm sure you will get by fine since you probably wanted to put an accessory on anyway. You can probably order a replacement in the meantime.
May 03, 2016 | Dremel Tools & Hardware - Others
Hard to start after gitting gas. that is the only time it happens
You may need a new gas cap. The only way to check it is to replace it. They're pricey, so first look to see if check engine light is on. If it is, go to a chain store parts house and have the codes read.
There is a technical problem with some of the 08 evaporative emission control system. The code check will tell if you need the repair, about $85.00.
The check is free. A gas cap about $30. So go have the code history read and see what you truck is telling you.
Oct 09, 2014 | 2008 Chevrolet TrailBlazer LT
Dremel 4200 stopped working
No.. the issue issue is the switch inside. when your Dremel 4200 stop working, press firmly the grey area between the speed selector and the brush housing. I think this a defect in the design of the 4200. 9f840401-fb84-4f7b-8c68-75a9be3ceb9e.jpg
Dec 31, 2012 | Dremel Tools & Hardware - Others
How to restore "caps lock" icon w7 acer aspire 5742
acer_aspire_5742z4200_pc_notebook_1709128.jpg Problem with Acer Aspire 5742Z-4200 (LXR4P02002) PC Notebook
rtaranto1 Asked on Jul 26, 2012:
how to restore "caps lock" icon w7 acer aspire 5742
Jul 26, 2012 | Acer Aspire 5742Z-4200 Notebook
Problem Siemens Gigaset 4000 and 4200
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Connecting external monitor
press "FN" KEY and press F5 or F6 key if you post your
keyboard layout photograph so i can better explain
Mar 29, 2008 | Acer TravelMate 4200 Notebook
Computers & Internet Logo
23 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
