Question about Ryobi Garden
What is the proper way to load the trimmer line on Ryobi model P2002 12" string trimmer? The string retracts after only a few seconds of use.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
Posted on Apr 23, 2017
How to install string for ryobi 50 volt string trimmer
Line Trimmer Line Replacement of a Ryobi One+ 2013 ...
? 2:33
Feb 22, 2013 - Uploaded by TheLegoCityBoys How to replace line in a garden Line Trimmer. ... Ryobi 40-VoltLithium-Ion Cordless String Trimmer RY40210 - Real World Review & How To ...
Aug 08, 2015 | Ryobi Garden
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Bought new Ryobi P2002P from local home improvement chain, less than 2 wks ago; after assembly and charging battery, I found the .065 string equipped with the string trimmer kept breaking when trying to...
My first choice for a repair is to return this unit to the store, so that they will know that what they are selling is not working.
My second choice is to have you put a good quality line on this trimmer. Ryobi has tried to save a few cents by using a very lightweight line. I have not had a lot of personal experience with battery operated trimmers, but my impression is that they are very light-weight and take significantly more time and effort to achieve the same result as their electric or gasoline counterparts.
Check your owners manual to see if you can use a size .080" trimmer line. Stay with round line. The square or star shaped lines tend to stick to themselves and don't feed well. If you have to stay with the .065" line, find your local lawnmower repair shop and see if they sell a higher quality line.
Good luck.
Oct 21, 2010 | Garden
Describe string replacement on ryobi trimer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jun 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
