Question about Coffeemaker Coffee Makers & Espresso Machines
Why does my Cusinart CHW-12 coffeemaker just shut itself off for no reason
4 Suggested Answers
SOURCE: Is their anyway to turn the beeps off when the pot of coffee is done?
Disconnect the beeper.
Posted on Jul 25, 2007
SOURCE: need replacement carafe for Cuisinart CUI CHW-12
cuisinart chw-12 replacement carafe is Cuisinart DCC-1200PRC 12 cup replacement carafe.
Posted on Jul 17, 2012
  • 47694 Answers
SOURCE: Cusinart keurig coffeemaker power switch
yep it has one
Posted on Apr 05, 2015
Makes popping noises
If the wires are shorting out you would either experience a power interruption, circuit breaker or fuse blow, and/or a smell of some sorts. If this is under warranty I suggest you turn it in for a new one. On the other hand, remember it is a percolator device and when water is heated to the desired temperature the action is for the hot water to rise and flow over the basket containing the coffee grounds. Percolation makes a popping sound, at that is a normal condition.
Dec 22, 2013 | Cuisinart CHW-12 Coffee Plus 12-Cup...
No display on panel. It is blank and I can not turn the coffeemaker on.
Check your breaker first. Plug in something you know that works. Next , check your off on switch. This is likely the problem. the switch may feel soft. remove the cover to it and you may see a wire that is burned off the terminal. with no lights, there could be just avloosecwire. t
Mar 14, 2013 | Cuisinart Chw-12 Coffee Plus 12-cup...
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Mar 13, 2009 | Cuisinart Coffeemakers
Cusinart DGB 550BK coffee maker not working properly
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart Coffeemakers
Coffee Makers & Espresso Machines Logo
Top Coffeemaker Coffee Makers & Espresso Machines Experts
pawnpower
Polo Joker
Polo Joker
Level 1 Expert
Are you a Coffeemaker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
