Question about Maytag Washing Machines
Maytag Atlantis MAV-39. It filled but then stopped and I can't get it to start again.
vest6
  • 196 Answers
SOURCE: My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Posted on Jan 15, 2008
yalmer
  • 549 Answers
SOURCE: MAYTAG WASHER DOES NOT SPIN AND DOES NOT DRAIN
Something may be stuck in the belt or inside of the machine.
The following may help.
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Posted on Feb 14, 2008
  • 1073 Answers
you have a bad motor
Posted on Apr 16, 2008
SOURCE: SQUEAKY DRYER
HOW DO YOU ACCESS THE REAR DRUM TO APPLY THE OIL?
Posted on Mar 31, 2009
EllaWatson25
  • 725 Answers
SOURCE: maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Posted on Aug 14, 2009
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
How to replace a drive coupling on a maytag atlantis series mav 6300. I heard a loud cracking noise, then the washer stopped.
you will need a sevice manual go to appliancerepairplanet.vstore.ca it will show you how to do it
Dec 08, 2010 | Maytag MAV6300 Top Load Washer
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Lint in the wash water/clothes
If you have a regular tub/agitator machine you can fill 1/2 with water, add two cups of white vinegar & allow it to agitate but not empty. Give the machine a break to 'soak', then agitate again. Allow the vinegar-water to sit in the tub between rounds. Do this for the whole day (on weekend?) to give the machine a good cleaning. Often soaking in vinegar will loosen trapped debris so it can go down the drain. It will clean the machine very well even if it does not stop your lint problem. Sounds like there must be some part in the machine that got clogged w/ lint or that there is a hidden lint trap. Read the instruction booklet or try to contact the manufacturer via toll free phone or internet for troubleshooting on the problem. Good Luck!
May 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Jul 17, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
