Question about Samsung Dishwashers
Samsung dishwasher not finishing was cycle flashing smart auto and normal lights at same time and not draining out water please help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
Http://www.appliancepartspros.com/diy-story-error-code-over-fill-flashing-smart-auto-diy916377.html
Posted on Apr 22, 2017
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Samsung dishwasher fills and drains repeatedly
I would check the drain itself. Make sure there aren't any eating utensils getting caught in the drain area.
Jun 01, 2015 | Samsung Dishwashers
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
My Samsung Dishwasher keeps flipping cycles during the course of its run. I set it to "normal" and it ends up on "delicate". Dishes seem to be clean, but are still wet after the 2 hour run time. Help...
I'll bet that Delicate light is flashing, which is actually indicating an error. You didn't mention your model number, but in most Samsung dishwashers I'm familiar with, that light indicates a Drain Error. You may have something hard caught in the impeller of your drain pump, or you might have a bad ECS sensor. In any case, it's time to call a dishwasher repair technician. For Samsung dishwashers, I recommend calling Sears Service (1-800-4MY-HOME or 1-800-469-4663).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 26, 2014 | Samsung Dishwashers
Low water level
Try to unstick the float. The float tells the DW how much water is in it at any given time. It is shaped like a mushroom on the bottom of the DW basin. Gently pick it up and set it back down. Does it seem free? Try the cycle again.
Jan 10, 2014 | Samsung DMT400RHS Builtin Dishwasher
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
2-3 inches water left in bottom of dishwasher after it finishes it's cycle model DU81OCWDQ5
The model number of your dishwasher is DU810... (zero not O).
Please refer page 28 of user manual. It is normal for some water to stay at end of cycle. However, check if the air gap (if insalled) is clear. Also make sure the kitchen side of drain hose is clear.
Unless there is a fault condition shown by flashing lights, then it is pretty normal operation.
In case in future you need to refer to the parts of your dishwasher you can refer this site.
Jan 02, 2011 | Whirlpool Dishwashers
Dishwashers Logo
432 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
