Question about Denon AVR-2106 Receiver
Denon AVR2106 receiver lost center channel, third time
The center channel has failed again on my AVR2106, it has been repaired by Dennon twice before. Failed at 11mths, failed at 13 mths and failed at 36 mths. Each time I checked the speaker, a JBL unit and the wiring, no issues were found. Can anyone offer any solutions to the problem. I am in discussion with Denon at present to see if they will help me as I believe I have a "lemon". My components are in a ventilated component cabinet in an air conditioned room.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Its possible you center channel is fried and keeps burning up the channel output on the reciever. Next thought is that, yes it was a bad model. First make sure that the speaker is good by putting another speaker in its place, or by checking the speaker with another system for sound quality. If it sound high pitched and it takes alot of volume to hear, than its toast and get rid of it.
Posted on Jul 25, 2009
Denon troubleshooting
Check all the external wiring to the speakers, etc.
Look for loose connections or even completely broken ones - good luck.
If all else fails then you'll need to consult your nice friendly repair person down the road.
Jan 09, 2014 | Audio Players & Recorders
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
I have an AVR2106 shuts down right after being turned on
You have a bad channel or power supply problem and need to send the unit for repair. You may send it to ebcelectronics here is a link.
Aug 13, 2009 | Denon AVR-2106 Receiver
I own a Dennon AVR-1905/785 surround receiver. The right channel is not emitting any audio. Am I better off trying to have it repaired or simply purchasing a replacement unit, not necessarily Dennon. Thank...
could be a rca jack gone bad,,unless you hooked it up digital,,with coaial or fiberoptic dts cables,,then it may be a bad speaker wire or at the conection at either end,,, dennon,,ive never haerd of htat brand,, you cant go wrong with a jvc,,or technics,,
Oct 06, 2008 | Denon Audio Players & Recorders
Denon avr 2105 died (3 times) dead AVR2105 faulty avr-2105
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Jul 19, 2008 | Denon AVR-2105 Receiver
Dennon 3930 dvd player unable to play sacd in 5 channels only in stereo.will play dvd-a disc in 5 channels
For DENON DVD-3930: In "setup", HDMI sound settings have to be "2-channel". Then SACD 5-channel output is enabled.
Jul 14, 2008 | Denon DVD-3910 DVD Player
Power wont stay on
Hope your under warranty mate and if so hope its not in Australia as they cannot fix this problem. My denon was allegedly fixed twice but has now failed a third time (just out of warranty) and denon have turned their back on me.
SHAME ON YOU DENON.
Jul 08, 2008 | Denon AVR-2105 Receiver
Denon AVR 1803 Receiver lost audio
Make sure your receiver is set to either "auto-select" or "digital" rather than "analog" (button on front display).
May 25, 2008 | Denon AVR-1803 Receiver
I took my Denon receiver to a local repair facility, because it wouldn't fully "boot", after shutting down, when I tried to run a computer rca plug (on both ends) from our computer to a in wall -...
Please post the exact symptoms. What do you mean by not "booting up"? Does it click on then click off? This would mean that the unit is in protect mode which is usually caused by a problem with the output amplifier section not the Micro. Do you have any experience with electronics repairs? If so, I can try to guide you through the repair.
Let me know.
Dan
May 09, 2008 | Audio Players & Recorders
Denon AVR-2106 Receiver Logo
404 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
