Question about Samsung Televison & Video
Changed T con on samsung tv but did not help. Still have vertical lines. T Con part numbers were not identical but boards looked exactly the same. Could it be something else?
TV Model is UN48H6350AFXZA.
    Sergeant:
  • Samsung Expert
  • 329 Answers
Any vertical or horizontal lines on a LCD display panel it indicates that the panel is defective.
Posted on Apr 24, 2017
My Sharp TV LC60LE660U has black vertical lines. The T-Con Board is DUNTKG477FM01. I have a broken Sharp tv with a T-Con board number DUNTKF975FM08. They look exactly the same, can I switch them out?
Look whether the two of them are of correct number. If not, they can't be matched. If you wish to get some details; check the site linked here. Pull up older posts. Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 09, 2016 | Sharp Televison & Video
How do I fix a washed out picture problem on my 46 inch samsung series 7100 led tv?
The common cause of this issue is down to a board that connects the screen to the main circuit video board of the tv. It is usually located top middle of the tv and has 2 white ribbon type wires coming from the top and is normally covered in a metal shield.
There will be a part number on the circuit board, this will be the one to find online which matches your screen. If you got an identical tv with another fault, it may not have the same part as each combination is different depending on the manufacturing line or part revisions.
The part you are looking for is called the T-Con board . Hope this helps.
Apr 02, 2016 | Samsung 7100 Series UN46F7100AF 46" LED...
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
www.electro-medical.blogspot.com
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
Coloured vertical lines on right hand side of screne
Yor tv have problem with T con board. T con board is one which drives the pixels of the LCD panel. If any of the driver satge in the T con board is faulty then this problem can occur.
Some times bad contacts on the connections of the t con board can cause same problem. Remove the tv and find out the t con bard. Remove the connections to it and the reconnect the connections. Then check, if the problem remains the same then the tv need a new T con board.
You have didn't mentaioned any model number of your tv. So it is not possible to show you exactly how T con board looks.
Normally in all lcd tvs the tcon board is place on the bottom or top middile position. Which will be cover with metal cover or aluminium foil.
Here I have added a link which will lead you to the picture of T con board for toshiba.( Not exact one)
T con
Ajin
Apr 01, 2012 | Toshiba Televison & Video
VERTICAL LINE ON LCD TV
You didnt specify the brand and model number of your TV any way the above mentioned problem can occur when the T-con board of the lcd Tv have some problem. There is no repare possible with these boards. The t-con board controls the pixels of the lcd panel. When any one of the out put from the t-con is faulty then the specific pixel or row of pixel will be absent. That's we see as lines or missing pixels. You can find the T con board normally in the bottom centre or top centre of the LCD tv covered with metal cover or aluminium foil. There will be a part number in the board. You have to replace a board with the same part number.
Some time there will be some loose contact in the connections of these board can cause these problems. Before going for a new board remove all the connection to the board and then reconnect it. If then also the problem is there then you need to replace the t con board. This is a common problem to the lcd TVs. Normally t con board will look like one in the picture. If you need any more assistance fell free to contact me through fixya. Next time when you post a question remember to add the make and model number of the product.
Dec 24, 2011 | Televison & Video
Samsung LN46B650T1FXZA has vertical lines. What part needs to be replaces? Thanks, Nina
This might be a bad T-Con Board. This is the board that is in the middle top side of your TV. It connects to your main board (with the hdmi inputs) to the LCD Screen. Your TV has a major issue with the T-Con Board going back. The T-Con for that TV is avaialble here 55 46T03 C11 Samsung Con Board for LN46B650T1FXZA
Jul 23, 2011 | Televison & Video
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
