Question about Cell Phones
  • 163 Answers
You can find a complete manual of spare parts
Trust this helps
Sir Taylor
Posted on Apr 22, 2017
I have a SUREBONDER ELECTRIC NAILER/STAPLER 5900 where can i buy the nails at
Use Surebonder® #4 or Arrow® T50® heavy duty staples, #8 brad nails and #9 pin nails. You can get the Arrow T50 items and most home stores.
Nov 08, 2017 | Electric Tools & Hardware - Others
Where can i get a assembly diagram for a surebonder 5900n
There is no assembly diagram available for the Surebonder 5900N.
Sep 25, 2016 | Surebonder 5900 Electric Staple Gun
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
How do you load staples into a surebonder model 9630?
Loading a 995630. Hold gun upside down with front of gun in left hand. Open track release with right hand. Lay one section of 1/4" crown staples in the bottom of the gun itself, in front of the track. Slide track over staples. Store tool at room temperature. New gun needs 6 drops of air tool oil through the air inlet just before first use. If you do not have the recommended automatic oiler installed on your airline, you will need to manually oil with three drops every 3rd row of staples. Run PSI around 80 and never exceed 100 PSI on your air compressor.
Sep 01, 2014 | Surebonder Pneumatic Stapler
Surebonder 9600
Call the manufacturer with your email address and ask for detailed instructions on how to replace the pusher and spring on your specific model number.
These are instructions on replacing the spring and pusher for Pneumatic model #'s: 9600, 9610, 9615.
1. Wearing protective eyewear, remove air line supply HOSE from your gun, turn gun upside down holding the front of the gun in your left hand
2. Remove u-shaped piece that holds the track in place at the back of the bottom of the gun.
3. Slide track out of gun.
4. Take the long black spring (part # 38) and hook one side of it to the hook inside the pulled out track.
5. Feed the other side of the spring under the silver wheel in the front of the track and pull it up holding the tension. You might need to use the end of a paperclip to feed the spring through.
6. Take the u-shaped pusher (part # 33) and place the other end of the springs hoop onto the hook inside part #33. Make sure the opening of the hook faces the back of the track, and that you see the yellow tape so that it will show in your view window.
7. Carefully place part #33 with the spring attached and the opening of the hook facing the back of the track, back onto the front of the track. The springs tension will hold it in place.
8. Carefully slide the track back into the bottom of the gun making sure you are placing each side of the track into the grooves.
9. Carefully snap the u-shaped lock back onto the bottom of the track to hold the track in place.
10. With the tool upside down, slide your track open and be sure to place your staples in the bottom of the gun itself with the points of the staples pointing up towards the ceiling, not on the track.
Parts are available online at on the left hand column, select Pneumatic Parts, then select your tool. It will bring you to the ordering page.
Mar 17, 2013 | Surebonder Pneumatic Stapler
How to get GPRS for my blackberry 9630?
To get GPRS/MMS setting, you need to contact your service provider through phone or go directly to their office.
They will send you the settings for your model. You will receive service settings in the special text message called as smart message. Please save the settings to your phone and set it has default settings. Then you can start using the GPRS/MMS in your phone.
Thank You
Sep 07, 2010 | RIM BlackBerry? Tour 9630 Smartphone
The last e-mail my phone was mar 23 2010. what happen? my pc has 800 e-mails.
go to your personal email setup folder and log in with you b'bery user name and password once logged in click help then click on send service books ,that should reconfigure your mail and should start working within 20 mins or sooner
Mar 30, 2010 | RIM BlackBerry? Tour 9630 Smartphone
My call waiting feature is not available on my phone and cant seem to find out where this feature is... called my provider and the feature is available on my service
If someone calls in while you are on the phone, you should just be able to click "answer." To switch back, push the trackball in and click on "flash" in the menu that appears.
Feb 03, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
