Question about Weiser Lock Locks & Locksmithing
My weiser lock started squelling & no matter what I do it will not quit. Even with the batteries out & the sound button turned off it still keeps on squeeling.
    Sergeant:
  • 163 Answers
Here is the manual with complete install / trouble shoot
http://www.weiserlock.com/PDFs/install_sheets/SmartCodeLeverManual.pdf
Trust this helps
Sir Taylor
Posted on Apr 22, 2017
How do I enter new code?
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Nov 26, 2015 | Weiser Lock Locks & Locksmithing
Solid red light after installation of battery and setup of crank. Door locks twice when hit lock button
The bolt might not be lined up correctly. It needs to operate freely. Make sure bolt operates smoothly with key and turn button .
Jul 15, 2014 | Weiser Lock Locks & Locksmithing
I have a weiser lock. when i punch the buttons the motor is heard but the plastic gear isnt turning. the bolt will come out alittle sometimes and then others not. ichanged the batteries so the motor is...
If your lock has previously been working, then developed this problem, you likely have developed a mechanical problem within the lock.I recently helped someone else with a Powerbolt that would not fully extend and retract--he thought it was an electronic problem at first. Then he removed the deadbolt assembly and found, in his words, "the deadbolt is ensconced with a plastic sleeve when it retracts into the latch housing. The sleeve is shattered and most likely to be the cause of its malfunction." Something to look at!
Weiser claims to have a full lifetime warranty on mechanical parts. Contact information:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Good luck--and please provide feedback if this helps!
Sep 19, 2011 | Weiser Lock Powerbolt 1000 Lock
Unit starts beeping like code is being entered . long beep sounds afterward . none of the buttons make any sound when depressed.Changed batteries,problem remains
Powerbolt is Beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
This is the link to Weiser Customer Support Page:
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Aug 12, 2011 | Weiser Lock Powerbolt 1000 Lock
Changed the batteries but the Weiser keypad lock keeps beeping
Mine did that too for a month. Make sure all the batteries are new alkaline batteries of the same brand, and remove them for a few minutes (if already installed) and replace them in the unit. I reset my code as well afterword. Did the trick for me.
Aug 23, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
I installed a weiser smartcode lockset and the motor is turning the wrong way. How do we fix this?
2 important things which may seem dumb but solved my problem:
- Make sure that once everything is in place, you hold the lock button before inserting battery pack (and keep holding the lock button) until you hear 2 beeps. The latch should come and go.
- Last but not least, make sure you put NEW batteries in... I had old batteries and when i tried it seemed like is was working but could not finish the door direction finding sequence stated above. Make sure they are new and it should work!
Feb 14, 2010 | Weiser Lock Locks & Locksmithing
Dear Sirs: I have a Weiser keyless locke
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
-=dån=-
Jul 15, 2009 | Weiser Lock Powerbolt 1000 Lock
Powerbolt 1000 started beeping and quit functioning
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Jun 14, 2009 | Weiser Lock Powerbolt 1000 Lock
Locks & Locksmithing Logo
287 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
