Question about Sunbeam Irons
I have a sunbeam 421a Steam Master iron. The cord is stuck and it won't retract to pull back in or pull out more to use. Can the base on the bottom be taken off to fix the problem inside?
SOURCE: Repair of Steam Iron
I just removed the two screws on the bottom of the cord winder and made the screws tight again, works like a charm.
Posted on Jun 20, 2008
SOURCE: Sunbeam 4214 Clothes Iron with Retractable Cord won't heat.
first, i'll apologize for not posting pictures with this, but i didn't have a camera handy when i "fixed" it. i'll do my best to explain the sitch.
i also have a sunbeam 4124 whose retractor was jammed...the cord would not release more than two feet or so, nor would it retract. i was able to disassemble it, but broke some internal retaining clips meant to hold the retractor housing to the iron. WARNING!! do not attempt this if you do not want to void your warranty. i can only assume that the manufacturer did not want you to disassemble the cord return housing and as such, hid the retaining clips where it would be impossible to disengage them. i got lucky and only broke one set of the retaining clips....if you carry on, you stand a chance of breaking both sets, which will not allow you to reattach the retractor housing to your iron securely. best thing to do is call sunbeam and have them send you a new iron, but if you're bent on fixing it yourself, here's how i did it (you'll need one medium philips head screwdriver):
1) remove the rubber feet from the bottom of the iron. this will expose two screw holes (the third foot under the retractor button has no screw; this is the side where the reaining clips are buried).
2) remove the two screws
3) WARNING! this is where you have a good chance of breaking your iron. pull the base of the iron really hard, rocking it from side to side. there are two sets of retaining clips recessed in the housing of the iron. the button will come with the base of the iron, the entire cord retraction assembly is self-contained. you can carefully use a screwdriver to pry the two halves apart. also, be careful not to pull too hard as the electrical connections between the iron and the retractor assembly has only about 2 inches of slack, though the connections are just wire-nut'd together and could be reassembled in a pinch.
4) after the retractor housing is separated from the iron, remove the housing cap by unscrewing the four screws.
5) carefully separate the two halves of the housing; the spring may be loose inside and could snap out at you.
here's where my iron was broken....the coil spring is contained by a plastic tray that had snapped, probably due to somebody pulling the cord out too hard. a section of the tray had jammed itself into the inside of the housing, immobilizing the winding mechanism. my only recourse was to completely remove the spring and permanently extend the cord all the way (not one of the features i bought the iron for anyway, so what the heck). PLEASE be careful unwinding the spring if you have to do it....wouldn't want anybody poking out an eye inadvertantly.
6) reassemble the retractor housing by screwing the cap back on with the four screws
7) if you're lucky enough to keep one set of retainer clips, snap the base of the iron back on and reattach the two screws located under the feet.
8) rubber pads back in and voila!
hope this helps!
Posted on Nov 03, 2008
  • 3230 Answers
SOURCE: sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Posted on Apr 06, 2009
konzzz
  • 255 Answers
SOURCE: Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
Posted on May 29, 2009
deme-tri
  • 90 Answers
SOURCE: Retractable Iron Cord Stuck
under the knob to press to retract the cord there is a screw,
slacken it ad try to adjust it again.
Posted on Dec 01, 2009
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
Mar 13, 2013 | Sunbeam 4214 Iron
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
Water leaks from bottom of iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jun 18, 2009 | Sunbeam Steam Master 4055 Iron
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
good luck...
Apr 06, 2009 | Sunbeam Irons
hope this helps!
Mar 17, 2008 | Sunbeam 4214 Iron
Retractable cord
hope this helps!
Jun 12, 2007 | Sunbeam 4214 Iron
Irons Logo
62 people viewed this question
Top Sunbeam Irons Experts
Tony
Henry  Thomas
Henry Thomas
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
