Question about Kodak Office Equipment & Supplies
Ink cartridge will not move on Kodak ESP C315 printer.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
Http://support.en.kodak.com/app/answers/detail/a_id/1332/~/printhead-and-ink-cartridges-dont-move-to-center-with-access-door-open&ved=0ahUKEwiWy7bY3LjTAhWIy4MKHUgZBqgQFggaMAA&usg=AFQjCNH21NGIJabFJ5e9lrD7jpnfyRbIpQ&sig2=haA83A253Fhql7hlWsuXAg
Posted on Apr 22, 2017
How to remove print head on a Kodak ESP 5250
If the ink cartridges and printhead are already in the printer, remove them, then reinstall them.
  1. Remove the color and black ink cartridges.
  2. Remove the existing printhead by lifting the latch in the center of the carriage. printhead_removal.jpg p342_0064aa.jpg ESP 3, 5, 7, 9, 3250, 5250, 5210,
    ESP Office 6150, 7250, 9250;
    HERO 7.1, 9.1, OFFICE HERO 6.1 ESP 1.2, 3.2, 3.2s, C110, C310, C315,
    ESP Office 2150, 2170;
    HERO 3.1, 5.1
  3. Close the printer access door.
Oct 21, 2014 | Office Equipment & Supplies
I replaced the ink and closed machine tried to copy but the replace ink keeps coming on,, what can I do?
Are you using Kodak cartridge? They have a chip that communicates with the printer. If non-Kodak ink cartridge, it may not work properly.
Oct 12, 2014 | Kodak ESP C315 Wireless Color Printer with...
How do you remove ink cart.
To replace an ink cartridge on a Kodak ESP C310 follow these steps:
1) Make sure your printer is on.
2) Lift the printer access door, and wait for the carriage to move to a position where you can access it. The ink cartridges are located in the printhead.
3) Pinch the tab on the ink cartridge.
4) Lift the ink cartridge out of the printhead.
5) Remove the new ink cartridge from its bag.
IMPORTANT:To prevent the printhead from drying out, insert the ink cartridge into the printhead immediately.
6) Remove the protective cap from the cartridge.
7) Insert the ink cartridge into the printhead.
8) Press down on the ink cartridge tab until you hear a click.
9) Close the printer access door.
That completes changing the ink cartridges.
Thank
Mark
Aug 25, 2014 | Kodak EasyShare Office Equipment &...
Kodak ESP C315 Error code 3513 missing print head
Kodak esp c315 .i have the kodak esp c315 and keep getting the printhead loose missing or not installed correctl
Apr 14, 2014 | Office Equipment & Supplies
Keep getting message print head loose or missing after changing the black cartridge on the esp c315
It sounds like youve pressed a bit heavy when fitting cartridge and disconnected the actual printhead itself. lift the lid as if to change the ink cartridge and check if you can clip the printhead back in place. It should be a case of simply pressing the chamber the cartridge sits in away from you until you hear it click.
Nov 27, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP C315
the kodak system uses a countdown system that assumes you use a certain amount of ink re sheet regegardless of how much ink you accutualy use, the counter system starts everyt ime you turn the printer on, so the only way to extend the life of the ink is not to turn the printer off netween use, which the domestic useres do not of course do what i did throw the printer away and get a new one not Kodak sh*t of course
Apr 04, 2013 | Kodak Office Equipment & Supplies
COLOR INK CARTRIDGE NOT RECOGNIZED
empty cange it. clean out the dust bunnys,air can two for five bucks . thks good luck.
Feb 22, 2013 | Kodak ESP C315 Wireless All-in-One Printer
How to remove the ink cartilidge
How do I install a new printhead in my all-in-one printer? To replace the printhead in your all-in-one printer:
  1. Make sure the printer is on.
  2. Lift the printer access door and wait for the carriage to move to the access position.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers:
    • On the printer control panel, press Home.
    • Select Maintenance, then press OK.
    • Select Install Ink Cartridges, then press OK.
      If "Install Ink Cartridges" is not an available selection, upgrade the firmware.
  3. Remove any paper that may be loaded in the printer.
  4. Remove the black and color ink cartridges and set them aside.
  5. Remove the existing printhead:
    • For ESP Series Printers, unlatch the printhead by lifting the latch in the center of the carriage.
    • For 5000 Series Printers, unlatch the printhead by pressing the button in the upper-left corner of the carriage.
  6. Lift the printhead out of the carriage.
  7. Remove the new printhead from its bag.
    CAUTION: Do not touch the copper contacts on the printhead, as this may damage it.
  8. Remove the plastic protective shields.
  9. Place the new printhead into the carriage.
  10. Push firmly against the target label of the printhead until you hear a loud snap.
  11. Insert the color ink cartridge into the printhead and press down until you hear it click into place.
  12. Insert the black ink cartridge into the printhead and press down until you hear it click into place.
  13. Close the printer access door.
    The printer detects the new printhead. Follow the instructions on the LCD to calibrate your printer.
    NOTE: ESP 3 all-in-one printers do not require calibration.
IMPORTANT: Be sure to use KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. You can purchase KODAK Ink Cartridges from the KODAK Store.
Feb 09, 2011 | Kodak ESP5 AllInOne InkJet Printer
Reset chip kodak esp 7 ink cartridge
Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges. The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 16, 2009 | Kodak ESP 5 Printer
54 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
