Question about Toyota Sewing Machines
My Toyota sewing machine was working perfectly well, but suddenly stopped, the machine appears to be jammed, What do you think the problem is?
  • Toyota Master
  • 11,474 Answers
Probably the thread is wrapped in the bobbin area. Remove the needle and try to remove the bobbin case. Otherwise, very carefully snip the thread nest and pull the threads out piece by piece. Don't yank!!!
Posted on Apr 22, 2017
SOURCE: Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
Posted on Apr 09, 2007
  • 208 Answers
SOURCE: sewing machine stopped making the stich
Unthread the needles, rethread the loopers properly, then rethread the needles. Make sure that all four threads are pulled securely into the tensions and retry.
The loopers must always be threaded before the needles or it will not chain.
Posted on Jul 19, 2009
  • 22 Answers
SOURCE: Jammed spool pin on a Brother CE5000 PRW sewing machine
Try a little oil and let it set befor pulling.
Posted on Nov 10, 2009
Testimonial: "Awesome solution- thanks so much!"
SOURCE: Hello, I have a Brother
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Posted on Aug 10, 2011
SOURCE: Toyota 8001 has locked/jammed
since the machine has locked up & jammed the machine needs to be serviced, to see if a part is damaged & to see if the machine is out of time
Posted on Apr 16, 2012
Testimonial: "Thank You Debbi, I will have it serviced."
How can I get my machine to stop jamming
Have you tried oiling all moving parts. Go under presser foot under bobbin and remove all lint. Try to change the needle.
Oct 25, 2015 | Brother LB-6800PRW Project Runway...
Toyota super jeans machine went clunk and the wheel is very hard to turn
Sounds like something is jammed or jumped out of line.. Take it to a service centre...
Dec 09, 2013 | Sewing Machines
Toyota sewing machine foot pedal unresponsive then goes really fast.
Try to get another foot pedal. If that works then replace.
Oct 08, 2012 | Toyota Sewing Machines
Apr 14, 2012 | Toyota Sewing Machines
I was sewing and all of a sudden it started to slow down and stopped. Have tried to sew again and sounds like it is jammed. I have taken machine apart and there is nothing visible that can be in the way....
Please try removing the bobbin case and then move the wheel. It is very likely that the bobbin case came out of place and causing the machine to lock up.
May 11, 2010 | Brother SE-270D Computerized Sewing...
My singer touch & sew suddenly didn't stop
There might be something jamming the petal open so it won't slow or stop when you put your foot on it.. I would try that, get some canned air and blow it out and see if it helps.
Apr 28, 2009 | Singer 1120 Mechanical Sewing Machine
Sewing Machines Logo
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
