Question about Stihl Garden
Stihl leaf blower won't start. Good spark . Replaced plug. Attempted start, negative, removed plug, plug dry. Primed, thumb over plug hole, pull cord, thumb dry. Tiny starter fluid, negative result.
    Sergeant:
  • 342 Answers
Try and see if it will start with a tiny amount of fuel poured into the block. If it fires then it could be the gaskets on the carb need replacing or it could be a blocked air filter. Check the later first.
Posted on Apr 23, 2017
Stihl br350 backpack blower will only spark when pulled fast. It will not start pulled fast or slow!
To start a small two stroke engine the rope needs to pulled rapidly. So from what you are saying I believe that your problem may not be in the ignition system. An engine needs three things to start and run- air, fuel and spark. Make sure that it is getting enough air by checking the filter and make sure if its a foam element that no foam has torn from the element and been sucked into the engine. Clean or replace a dirty element. Check the fuel filter and make sure that fuel can flow freely through it. Even a tiny amount of dirt can clog a filter enough to hinder flow to the carburetor. Replace the filter if it's dirty or over a season old. Clean the carburetor THOROUGHLY! Use a good quality carb cleaning spray and make sure the diaphragm isn't hardened or creased. Replace any part that's questionable. A way to test start the engine is to put a few drops of pure gasoline in the spark plug hole and quickly replace the plug and pull the cord to start it. If it starts for a moment the ignition system is good. Don't do this more than a few times cause a two stroke engine requires oil in the fuel to lubricate the rotating assembly and running straight fuel for more than a few seconds can damage the engine. Do not use starting fluid it damages two stroke engines.
Nov 23, 2016 | Stihl Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Oct 24, 2012 | Garden
I have a PB251 Echo blower that won't start. I have a good spark Good compression and clean new gas is getting to cylinder because i have a wet spark plug when i removed it ,yet it won't even...
I suggest cleaning the carburetor and replacing the diaphrams. The diaphrams come with a rebuild kit that has a lot of unused parts.
Aug 31, 2011 | Echo Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
The start cord on the leaf blower won't pull out more than a few inches. Why is this?
pull your spasrk plug out and see if it pulls over then, cylinder might be fullof gas causing hydro lock condition,if so pullit till cylinder dries out then re-install plug and try starting. if all is good check your fuel cap to make sure the vent is working! If it's not venting this causes vacumn that pull fuel out of tank to cylinder after it is shut off...........Good Luck 2StrokeJim
l
May 23, 2011 | Troy bilt 4cycle Backpack Blower 32cc
Will not start, replaced fuel lines (1 was broken) and spark plug
does it even run at all for a short bit? If not pull the spark plug from the unit, place some part of the spark plug threads on the metal surround the spark plug hole in the engine, turn the unti manually with the pull cord/starter and see if you get spark, if no spark it could be the Ign. coil module, a bad spark plug wire, or a break in the wiring to the ign. coil module.
Jun 07, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
I can't get my Poulon leaf blower to start
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
Mar 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Yardbroom II pull start hard to pull
put a teaspoon of mix oil into the spark plug hole, some times the metal starts to bind in the engine. keep the wire off and the plug in and pull the cord a bunch of times until it starts to get easier, if you need to add more mix directly to the hole then do it. hope this helps
Mar 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Oct 31, 2008 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
32 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
