Question about Belling Ovens
My belling oven is not working it maked all the noises and fan comes on but it is not heating up, the top oven/grill does work
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1214 Answers
    SOURCE: bottom oven not working
    A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
    If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
    A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
    Posted on Jan 14, 2009
    barkencoa
    • 3463 Answers
    SOURCE: fan oven wont heat up
    If fan is workintg, but no heat, then replace oven element.
    If no heat or fan, then make sure timer is set on manual and not on auto
    Please rate my solution.
    Thanks.
    Posted on Jul 01, 2009
    • 12 Answers
    SOURCE: indesit fde20 main oven wont heat up
    sounds like the circular element at the back of oven has blown.
    Posted on Oct 24, 2009
    barkencoa
    • 3463 Answers
    SOURCE: Dead oven despite element replacement?
    If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
    What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
    Thankyou.
    Posted on Feb 02, 2010
    Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
    ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
    Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
    The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
    Hope this has been helpful
    john
    May 31, 2011 | Belling Ovens
    My Belling oven has no heat, but the fan &
    If the fan is working o/k, then there is little doubt that the oven element has failed.
    This is quite common with fan assisted ovens.
    The element is usually located at the rear of the oven compartment behind a removeable cover.
    Mar 29, 2010 | Belling XOU252 Electric Single Oven
    Thankyou.
    Feb 02, 2010 | Belling XOU592 / XOU593 Electric Double...
    Belling synergie oven grill comes on oven fan comes on all lights are working but no heat in the oven temp 200 setting on the oven symbol all plugs have been checked.
    I suspect tha the oven element is faulty.
    To access it, you will find it located at the rear of the oven compartment behind a removeable cover.
    Hope this helps you.
    Dec 13, 2009 | Belling Ovens
    The oven blew the electrics and now the heating does not come on. the grill and fan both work but not the oven
    If the fan is working o/k, then you need to replace the oven element, located at rear of oven compartment behind panel.
    Please rate my solution.Thanks.
    Nov 12, 2009 | Belling XOU252 Electric Single Oven
    Fan oven wont heat up
    Thanks.
    Apr 05, 2009 | Belling XOU252 Electric Single Oven
    Fan and grill works but not heating up
    Hi.
    If the fan is working o/k, then you need a new fan oven element fitting.
    Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
    disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
    Plz rate this solution.Thanks
    Dec 24, 2008 | Belling XOU252 Electric Single Oven
    Belling db3 oven
    yes its most likely the element they are common in burning out ....because the fans still running,
    Dec 17, 2007 | Ovens
    Ovens Logo
    Top Belling Ovens Experts
    ashburton
    Lawrence Oravetz
    Are you a Belling Oven Expert? Answer questions, earn points and help others
