Question about Hotpoint Refrigerators
How much power does a hotpoint ffa52 consume
Hotpoint fridge freezer daily consumption
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
Ffa52 hotpoint diamond freezer running too warm
change condenser fan clean condenser coil dust at bottom of ref stopping cooling processes.Just like if you put cardboard in front of your car it will over heat or if fan is not blowing air on condenser coil
will not cool it fan and coil at bottom of ref. remove back you will see the dust pet hair a big problem with ref.
Mar 04, 2015 | Hotpoint Refrigerators
Hotpoint ffa52 fridge freezer
that is likely where the link for water an elect is remove cap an check the connections. in transport its reconnected when the door is off. an sometimes they get loose
Jul 25, 2014 | Hotpoint Refrigerators
Hotpoint ffa52
a little tip you have to totaly defrost your f/f it will take a couple of days for the pipes in back to defrost compleatly and then dry it with a hairdryer and then plug it back in hope it helps
Jan 27, 2014 | Refrigerators
My two year old hotpoint FFA52 fridge freezer is not freezing the foods in the freezer and the fridge's body is worm, it sounds like it is working it just this two problem.help
since its been 2 yrs , there might be a problem with the condenser , the gas would have been empty, so its better if you get it checked by a technician, and refill the condenser.
thanks for rating Good luck
Jan 25, 2011 | Hotpoint Refrigerators
MY HOTPOINT FFA52 FRIDGE FREEZER HAS MADE A LOUD BUZZING NOISE A COUPLE OF TIMES BUT IT APPEARS TO BE WORKING OK. AT FIRST I THOUGHT THE BUZZING WAS COMING FROM THE TOP NEAR THE THERMOSTAT UNIT BUT I,M NOT...
If you can pull the unit out from the wall, find the motor compartment. There, you'll find a black can with the motor and compressor inside it. This usually creates vibration when running. Check the compressor's mounts, to see if they need tightening or have rubber grommets that have rotted away. The sound could also be coming from a fan somewhere in the machine. There might be a fan in the motor compartment. Find the vents inside the unit that blow cold air. Check the guards to see if a foreign object could have made its way into the vents and jammed a fan. Make sure you unplug the fridge before you stick any hands or tools someplace they wouldn't normally go. You may want to let the unit run while peeking in with a flashlight to locate the source of the vibration, but beware of moving parts and a shock hazard.
Apr 03, 2010 | Freezers
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
FFA45W
Hotpoint FFA47X fridge/freezer. I have had this fridge for 3 years now and has always on regular occasions decided to defrost when it feels like it and asks me to consume all the food immediately! I have wasted massive amounts of money on food and calls to hotpoint and have had a hotpoint engineer out to sort the problem about a year ago. It goes fine for a few months..then it defrosts all over again! Its just done it again, luckily I am not using the freezer anymore it only had some peas in there. Has anyone had this problem and solved it?? I would really like to use my freezer again but am loosing patience with hotpoint! I'd be very grateful for some advice.
May 11, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Power Consumption Refridgerators
I have a 10KW stik welder/generator. I have no problem running a large freezer and 2 fridges except for the startup current draw. I have a $300 transfer switch connected to a 60amp sub panel with current meters on each leg. I have to watch the current draw and turn on & off breakers. I do have to play the "green acres" game because I have the water heater, well pump, and kit ckt all connected as well. Coffee machine, toaster, oil furnace, microwave all have to take turns as well as the water heater(4500WATTS). Cost was about$3500 in 2001 and $600 for a generator shed. lots of my labor. Last time we lost power it payed for itself. 28 hours without a generator would have been a trip to a hotel and lots of spoiled food to dump. hot shower and coffee anytime a big +
Nov 20, 2007 | Vacuums
Refrigerators Logo
57 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
