Question about Hardware & Accessories
The transformer doesn't click on when it reaches the red peg. The timer wheel can then be moved to on with my hand.
  • 923 Answers
The transformer? As if there is only one transformer in the world? What equipment is it ... make and model and serial number, if relevant?
Posted on Apr 22, 2017
Fleck 5600 will not regenerate automatically. It will regenerate if manually started
Need more info ! Is this a meter control, or day wheel ?
Does the clock keep accurate time?
If you reach around the back of the timer control box, on the left hand side, can you feel heat from the timer motor?..It should feel a bit warm
Dec 06, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Problem starting lighting
Are you sure the Peg is in the right way around? usually there is a short side and and a long side on the Pins?
May 21, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Timer stops at on postion? transfomer works, have to do it by hand
If the timer is stopping, it could be a physical obstruction. Or it could be an electrical mis wiring so that the timer is turning itself off at that point, check the incoming wiring and see if it makes sense, and follow the diagram to see if the incoming power is definitely not on any switched terminals, they would maybe be marked with NO , NC,
May 04, 2010 | Intermatic Malibu 300W Power Pack...
Have a new woods tn300 light timer. if lift the
Anywhere that pegs are pulled up is where the outlet is off if the pegs are down then the outlet is on. Hope that helps!
Jan 09, 2010 | Kitchen Appliances - Others
Malibu landscape transformer
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Apr 14, 2009 | Intermatic Malibu 300W Power Pack...
Freezer not defrosting between cycles
Check the defrost timer for operation if your unit has one. Some Delfield models have solid state controls. If your system has a timer for the defrost you can open the timer cover and turn the dial in the direction indicated by the arrow until a time peg comes up to the time of day marker. You will hear a loud click and the compressor will shut off. Defrost should take place. The inner dial of the timer will have some indication as to how long in minutes the defrost should take. If the pointer does not move while in the defrost position the timer motor is bad. Turn the dial again so the copper pointer goes past the time of day marker and the compressor should restart. Replace the timer.
Jul 04, 2008 | Delfield 113.28 cu. ft. Commercial Freezer...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
