Question about Refrigerators
Ice maker not working - Refrigerators
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    GE Profile Model PSS26LGSC Ice maker not working
    Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
    Apr 07, 2013 | GE Refrigerators
    Ice maker
    Before going to buy any parts directly.
    Go through this troubleshooting help links.
    This is list of refrigerator problems, which is normally faced in refrigerator.
    You can go through the details, by clicking the link below:---
    Refrigerator is not cooling properly?
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    Both refrigerator and freezer not cooling properly in refrigerator?
    http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
    The ice maker not working: ---
    http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
    Compressor not running on refrigerator?
    http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
    Water dispenser not working on refrigerator?
    http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
    Ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
    Water Overflows in Ice maker and freezes inside?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
    How to replace Ice maker assembly?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
    other ice maker related issues and solutions:---
    Ice maker dispensing ice with black or white plastic pieces in ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
    After replacing ice maker assembly, ice is not getting made?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
    Ice maker is leaking water and causing the ice to freeze?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
    Ice maker is noisy and not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
    Refrigerator ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
    Ice maker leaks water into ice bin causing a glob of ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
    Amana Refrigerator leaking water from ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
    Ice maker leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
    Ice maker is dumping the ice cubes out before frozen solid.
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
    Water overflowing ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
    Ice cube is getting stuck up hard in ice maker
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
    Icemaker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
    Quit making ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
    Water leaking into ice tray, frozen glob of ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
    Not making ice, and water leaking in freezer?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
    The ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
    Ice maker not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
    Ice maker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
    Ice maker dispensing black pieces of plastic in the ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
    Replaced Ice maker but its still not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
    Ice maker leaked creating an ice block?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
    Ice tray leaked?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
    Ice maker stopped functioning?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
    Ice maker stop working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
    Ice maker failed
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
    Old ice maker stopped working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
    Old ice maker started leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
    Ice maker not working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
    Ice maker overfills and cause water to flow into ice dispenser and freezes?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
    Ice maker didn't make ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
    Ice maker was leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
    Ice maker was leaking after it filled up with water?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
    These will help.
    Thanks,.
    Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
    The ice maker appears not to be working can not
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    May 31, 2010 | Liebherr KIKNV3056 Bottom Freezer...
    heatman101
    uiouio67
    May 24, 2010 | KitchenAid Architect 25.3 Cu. Ft....
    heatman101
    fdfdfs43
    Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice maker is not working. I hear water running to ice maker but no ice is being produced
    heatman101
    kjjhfkj
    Jul 02, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
    Ice maker will not make ice, water dispenser is working
    heatman101
    oypyiooiyp
    May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    ICE MAKER NOT WORKING
    heatman101
    Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Refrigerator ice maker stopped working
    heatman101
    mnnmbnm
    Refrigerators Logo
    23 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
