Question about Miele Washing Machines
How do I repair a miele washing machine, that is noisy and jumps around
  • Miele Master
  • 4,394 Answers
It is probably a suspension problem.
The wash-tub is supported by a mixture of rubber blocks, springs and dampers depending on make and design and it is probably one or more of these that needs attention. Removing the top for a closer inspection is necessary but if it is the underside that is giving trouble the machine will need turning over or perhaps dismantling.
Posted on Apr 22, 2017
Testimonial: "Thank you Vernon, that was good aadvice - I will try Ooops! I am not sure about how the voting works - but I tried to give a goos vote, it says just nr 1, is that a good rating or a bad one?"
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
My miele w3725 front loader washing machine appears to be leaking drops of oil into the wash and staining the clothes. What could be the cause?
Hi dear,
Seems like your washer has bearing seal damage. It will be expensive repair. You may contact Miele to get a quote. Thanks.
Jan 01, 2016 | Miele Washing Machines
I am looking for a new door seal for my Miele washing machine. its a brilliant machine but is leaking badly now. model W1712. your assistance in finding one for me would be very much appreciated.
Hi.
Miele make an excellent machine and I would advise you to have the door seal replaced by an experienced technician. The job is not as straightforward as it might appear.
I suggest you contact 2 or 3 repair people and check prices. Try to get some idea of the final price because the labour cost can be open ended and a big surprise...
I generally allow around an hour for a door seal replacement. It can take longer.
Good luck,
Nomess
Mar 03, 2015 | Miele Washing Machines
My miele washing machine keeps tripping out
try replacing the breaker first,they wear out too.low cost try.if no fix call repair help.
Mar 16, 2014 | Miele Washing Machines
Hoover washing machine very noisy on spin cycle, removed the back panel and black sooty deposits on rear of drum
when you open the back did you check if belt has jump out (as they are grooved) or is wearing out, any other rubbing surface rubbing around, locate where the black sooty is coming from and i might be able to find the right answer.
Aug 09, 2013 | Hoover Washing Machines
Control knob snapped off.... wonderinff if this is an expensive repair. The washing machine is a miele m404 plus.
if it was just the knob no if it was the whole control yes very expensive the control arm cost around $ 300 but it would not damage it there must be more to this story if you simply need the knob - plastic control you can order it from here they cost around $ 30 www.meile.com
best of luck
Dec 28, 2010 | Miele Washing Machines
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Rinse light flashing on miele novomatic washing machine
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
Sep 02, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele W 1918 washing machine front door seal replacement
the seal on the front door runs around 60 bucks and its quiet easy replaced takes 1/2 hour
May 27, 2008 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
