I need the wiring diagram for a Nordyne GS3BA-024KA condenser
I just need to know which wires go where on the run capacitor.Wiring diagram is faded inside control panel cover!
  • Heating & Co... Master
  • 1,929 Answers
3 wires for compressor, 3 for fan. 2 comp. wires go to the top of the contactor, the remaining goes to herm terminal on capacitor. 1 fan wire goes to the top LEFT of contactor, remaining 2 go to com and fan on capacitor. You will then have 1 wire left that goes to the com on the capacitor and should go back to the top RIGHT of the contactor. NOTE: IF YOUR FAN MOTOR IS RUNNING BACKWARDS (MEANING AIR IS NOT BLOWING OUT OR UP) swap the to fan motor wires on the capacitor (fan and com) this should reverse rotation. ALWAYS REMEMBER TO TURN POWER OFF AND DISCHARGE CAPACITOR BEFORE TOUCHING WITH INSULATED SCREWDRIVER. Good Luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Apr 22, 2017
Download for NORDYNE EIEHO15HA WIRING DIAGRAM
For a wiring diagram you will most likely have to request it from Nordyne.
Aug 25, 2017 | Heating & Cooling
I need the wiring diagram for the blower on a nordyne furnace
For a wiring diagram, contact Nordyne directly.
Apr 23, 2017 | Heating & Cooling
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Need wiring diagram on compesor
The compressor has three terminals, Common, Start and Run.... The terminals read left to right, top to bottom just like pages in a book. So if theres one on top, its Common then Start will be the first one in the next row. If theres two on top, it'll be Common on the left and Start on the right then Run on the bottom.
The run capacitor wires in between Start and Run and line voltage is applied to Common and Run.
Apr 11, 2015 | Goodman CKL36AR36 Air Conditioner
Acura 2002 RL
Check for a bad fuse..not sure where it is but look in the owners manual or inside cover of the fuse panels for the wiring diagram
Feb 25, 2014 | Motorsports
Wiring diagram for BlueRidge Spa
The wiring diagram for each spa is located on the inside panel of the control box.
Remove the side panel of your spa where the control box is located which is usually on the same side where the topside button is.
Once you remove the side panel you will see the control box.
Remove the front cover and on the inside of this cover is where the electrical diagram for all the wiring is found.
Rod
US Parts Center
Nov 02, 2013 | Pool & Spa
How can I attain wiring manuel for comprssor
A wiring diagram should be inside the control panel cover or the electrical panel cover.
Otherwise your neutral wire goes to common on the compressor and the L1 voltage goes to start and run on the compressor.
Aug 23, 2011 | True GDIM26 Commercial Refrigerator
Need a wiring diagram for a Smeg Oven SA392EB
I don't know about Smeg, but major appliance manufacturers in the United States generally put a wiring diagram inside the back of the oven, usually either on the back cover or on the back panel of the oven itself. In laundry equipment, sometimes it's folded up or placed in an envelope inside the control panel, but I suspect that would not be the case for stoves because there would be a greater risk of fire.
Dec 16, 2010 | Ovens
Do no what wires go where on the capacitor for our carrier a/c unit
Some capacitor start motors have two brown leads (one with white stripe) that go to capacitor. Others wire into the start winding, if that is the case follow wiring diagram on the motor. Also if this is in an A/C unit follow the wiring diagram in the unit (usually on inside of cover)
Jul 17, 2010 | GE 18 Hp Capacitor Start Ac Motor 115...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
