Question about Shark Vacuums
Shark rotator vac steam
Spitting dirt
Agent Don
  • 310 Answers
SOURCE: brushes do not rotate on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
Generic problem for all Vacuums
Brushes do not rotate on
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 09, 2008
  • 5 Answers
SOURCE: Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Posted on Dec 14, 2008
SOURCE: Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Posted on Jan 13, 2009
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac scrubbing brushes won't rotate -
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this problem.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on front, and 2 in the rear. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose *(one with a spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic pole has not broken.
If the pole is broken, you will simply need to replace the brush block assembly. The model F5914-900 uses Hoover 5 Brush SpinScrub Brush Block Part # 48437022.
Here's a direct link to this part on our GoVacuum.com storefront:
http://www.govacuum.com/hoovsteambru.html
If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Step on the handle release pedal so the SteamVac handle is lowered, and not in the upright position, as there is an internal switch that turns the brushes off when the machine is in the upright position. Now look inside the machine where the pole goes in. There is a green, square shaped female receptacle. This is actually the internal turbine that spins the brush block. Make sure that the switch for the brushes on the top of the machine is turned to "Rotating Brush Speed Hi". Turn the machine on.
If you saw the female receptacle where the brush pole is inserted was spinning, then your turbine is fine. If this part is not spinning, then you will need to replace your turbine.
I hope this helps you with your problem. Please feel free request a clarification request form here on Fixya if you have any questions, I'm always happy to answer follow up questions you might have. If you found this repair helpful, please be sure to rate it helpful by clicking the thumbs up icon. Thank you.
Chris J.
GoVacuum
Posted on Apr 04, 2010
  • 1493 Answers
SOURCE: brushes won't rotate on hoover steam vac
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Posted on Jul 18, 2010
Having problem with steam not coming out to do floors
Hey, this is Jeremy with Crucial Vacuum,
I am sorry to hear that you are having problems with your Shark Steam Vac. One solution you can try is to create a solution of approximately 50% water and 50% CLR (calcium, lime, and rust).
Put the solution into the water tank of your vacuum and let it sit for awhile. Over time your vacuum may have developed a build-up of calcium which is blocking the pores that release the steam. This solution should break-down the calcium and allow steam to flow out of the vacuum.
If you do not have CLR on-hand, an alternative found in most kitchens that can be used is vinegar. Again, make a solution of vinegar and water and allow it time to sit in the tank attached to the vacuum. Then try running the machine.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 06, 2015 | Shark Rotator Vac-or-steam 2-in-1 Hepa...
Why won't shark cordless stick vac motorized brush work?
Is the brush rotating, if not the belt is broken or jammed, if so remove the bottom plate and all will be reveiled.
Oct 17, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
Shark 2-in-1 Vac Then Steam
Steam frame and pad
must be attached to the cleaning unit
in order to use the steam function
manual > http://www.sharkclean.com/manual/MV2010_11_IB_ENG_110103.pdf
Apr 15, 2013 | Shark MV2010 Vac-Then-Steam 2-in-1 Vacuum...
I have a shark steam and vac and it has stopped steaming. the heater is warm so it is working but no steam??
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Feb 20, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How do I fix the shark vac and steam . the steam is not working
heatman101
Feb 10, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Do you vacuum with just the plastic bottom or should something go on it. do all shark steam vacs come with a storage tray because there was none in my box
This is NOT a vac... just a mop...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 05, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark vac is getting hot but hardlthe steam is coming out to
heatman101
mn
Aug 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
32 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
