Question about Coffee Makers & Espresso Machines
Jura Z5. Choosing cappucino the milk froth comes normally but coffee comes from espresso nozzles. What is the failure and how it will be repaired? The draining water comes from cappucino nozzle.
    New Friend:
  • 61 Answers
Inside the machine, at the front is only what I can describe as a see-saw.. it t
ilts either side to let the coffee exit from the left outlet, or the right outlets..
It is probably just sticking... as what happened to my machine, exactly the same as yours.
Remove the water container, and you will see two screws at the top.. they are an oval head, if you don't have the correct tool, try some pointed pliers. remove them, and the panel lifts away.. there are only a couple of screws holding the brew unit in, so you may as well remove and clean it.
You should be able to see the pipes going to the "see-saw" at the front, high up.. I belive it just clips on, so you can clean it.
Here are some links that will certainly help..
and the second page.
Posted on Apr 22, 2017
Jura impressa Z5 doesn't switch on anymore. A few days before just was displaying "maintenance" and then no more signs of life.
Search Results
    How to Fix Jura Z5, Z6 and Z7 - YouTube
    ? 16:03
    Aug 18, 2013 - Uploaded by Parts Guru
    I changed the filter, pressing button for System Fill, get message System is filling. .... My Jura Capresso Z5's milk frother doesn'twork. When I ...
    Jura Capresso Z5 Impressa - No milk frothing - YouTube
    ? 1:05
    Oct 25, 2013 - Uploaded by Frederic Valiquette
    Hi all, My Jura Capresso Z5 Impressa is acting up. The milk frother doesn't work anymore. When I ...
    [PDF]Instructions for Use, Manual JURA IMPRESSA Z5 - Esperanza
    The IMPRESSA Z5 - Generation II Manual. The 'IMPRESSA .... 5 Preparation at the touch of a button. 40 ..... As coffee and coffee specialities are very important to JURA, we have compiled a ...... It doesn't matter whether whole milk or skim.
    My Jura Impressa Xs90 won't switch on and nothing is - Fixya
Jan 31, 2016 | Coffee Makers & Espresso Machines
I bought a Krups 867-42 espresso cappucino maker from a second hand store. I need instructions on how to make espresso and how to froth milk. I have the necessary coffee pot to brew regular coffee, but...
Hi austyn90211,
Welcome to fixya!
Here is the user's guide to your espresso machine:
Handie Andie
Jul 15, 2011 | Vacuums
My jura impressa z5 is having trouble foaming the milk...worked fine last season but we can't seem to get it foaming the same as it was before...suggestions??
The common cause is that the frothing connection is faulty. You can look at the Guide to clean the Jura frothing connection, or try this. Take some bicarb or vinegar, dissolve in 400ml luke warm water, select cappuccino maintenance under the options, or press the milk button. Run the complete mixture through then. Run about 600ml of plain water through the spout. Turn the sport from froth to milk and back every 10 seconds.
If this does not work, then there may be a need to decal the machine.
Jan 24, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
I have an Impressa Z5 and it won't **** milk up the tube as either part of the cappucino program or the stand alone milk program. I've checked and nothing in the nozzle is blocked and the plastic pipe...
There are three possible causes to milk not frothing: 1. The frothing tap is blocked: to unblock either use the cappuccino cleaner from Jura, or in 400ml of luke warm water dissolve a teaspoon of vinegar or 1/2 teaspoon of bicarb and run this liquid through the frother until completely finished (or run the cleaning program). The run about 600-800ml of water through the system. While passing the liquid through let the tap rest at froth, and milk setting for 5 seconds at a time. Repeat if necessary. To prevent this in future clean frother after 5 minute of none use. 2. The breathing nozzle is blocked, you can use the Jura Maintenance guide to see how to disassemble and clean and reassemble, but most Juras come with a spare, so replace it. 3. The machine needs to be descaled, since there is lime or scale in it.
Jan 15, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
No milk,or steam coming from cappucinno nozzle
If you pull the cappacino component off. The black plastic thing at the end of the metal tube (where the cappacino component's attached to) can be unscrewed by rotating it with your hand. You can clean it with a brush and a thick needle to clean the hole the make sure that it's not blocked. After that just screw it back on and reattach the cappacino component.
Dec 16, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Steam and froth malfunction
The milk can not be room temperature.  It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
Feb 18, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Nov 05, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
