Question about Kenmore Dryers
What size circuit breaker for kenmore elite model99019
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
A 240vac electric ranges operates on 40amp
Posted on Apr 24, 2017
  • 67 Answers
SOURCE: Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Posted on Mar 21, 2007
SOURCE: What Size Circuit Breaker
a 750 watt heater at 240 volts draws 3.15 amps so a 2 pole 15 breaker with 14/2 wire would be fine
Posted on Nov 13, 2007
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
SOURCE: My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Posted on Jun 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: My electric range is tripping the circuit breaker
unplug the unit and see if maybe you have a problem in the breaker/supply line from the house panel, otherwise does it work fine?,there also may be a bare or shorted wire in the unit itself
Posted on Aug 23, 2009
How do you reset the computer on kenmore elite he3t steamer
UNPLUG FROM WALL SOCKET FOR 5 MINUETS PLUG BACK IN TRY AGAIN IF YOUR DRYER IS HARD WIRED DO THE SAME AT THE FUSE OR BREAKER
Oct 30, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Kenmore elite he4 blows circuit breaker
your element or motor has shorted as these r the only components that r earthed within the machine so check these first
Nov 10, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load dryer wont get hot ?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Nov 16, 2010 | Kenmore Elite 45986 Front Load Washer
Kemore elite dryer keeps knoting the breaker
Here is a tip that I wrote that will help you ti find out why the circuit breaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Oct 03, 2010 | Kenmore Dryers
I don't have heat to my dryer.
Make sure that Front of the dryer is not blocked, Air flow is needed to dry.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty heating element.You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated
Jun 29, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Jul 03, 2009 | Kenmore 63942 Dryer
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
