Question about Plumbing
I have a ladylux3 touch. When I touch the faucet nothing happens. I've tried all 5 parameters.
The auto touch faucet feature is not working, and no water is running out of the faucet. I changed the batteries and still nothing works.
Then the solenoid that turns on the water has failed or the batteries where installed incorrectly..
May 12, 2016 | Plumbing
Touch Screen Stuck On Incoming Call Screen?
Just Unplug the Power Supply and replug it in after 5 minutes, That should be able to fix the issue.
May 04, 2013 | Lexmark Platinum Pro905 multifunction...
See if all the connections are tight; try inter-changing the water pipes. Water should have good pressure at faucet.......
Apr 27, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Hansgrohe Solaris faucet will not return from spray to stream. The shuttle stays in the spray position
I would try cleaning the sprayer with CLR to break up and remove any deposits. If cleaning does not reolve you may need a new sprayer. The part number for the sprayer is 14893801 in steel optic. It is available through your local dealer or online dealer. Feel free to call me at Hansgrohe 1-800-334-0455. Press #2 for tech. Ask for David.
May 11, 2012 | Hansgrohe 06649860 Solaris Single Hole...
We purchased a 16927 Series SSSD 5 years ago. the faucet doesn't swivel on the base, so the nut securing the faucet to the sink continues to loosen under the sink. I've tried lubrication, I've...
There is a possibility of corrosion between swivel and base. Remove faucet and take to a work table and try and twist swivel spout off. I t may be tight, but the unit is not satisfactory and may need replacement. I have repaired such faucets before and many have been cheaper to replace. There a o rings between spout and body if you get it apart check mating surfaces any erosion discard unit. If OK replace o rings and use silicon grease. No petroleum products as this will cause o rings to swell. Good Luck
Nov 16, 2017 | Plumbing
The pull down mechism is very difficult to work. Its 6 yrs old and I've tried WD40 which doesn't help at all! It takes all my strength to pull it out when using.
Try spraying white vinegar on it and all around it, ANYwhere that water can settle. Water carries dissolved minerals such as calcium and magnesium. As it dries, it leaves a build up of these minerals, that in turn, form a hard, crusty covering that can cause a lot of various issues. The acetic acid in the vinegar will safely dissolve most of the deposits, making it easier to move. :) P.B.
Aug 16, 2011 | American Standard Kitchen Faucet 6310 020...
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Unsupported media/incorrect parameters
It is a poor quality player. It probably isn't built-to-last and as I can see, has problems. Try going into My Computer and right click it, Format it and select all the songs and drag onto the player and see what happens.
Apr 25, 2009 | Nextar MA933A MP3 Player
We are getting a metallic taste and smell
The metalic taste is coming from the the new faucet
I would call American Standard and ask them if they have any complaints for this particular model
I would run hot water through the faucet for 5 minute intervals
If it persists I would take it back and demand a refund or cal AS and demand a refund or replacement model
I am sure the local news would like to report something like this
Jan 05, 2009 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
