Question about Cycling
I have a classic ss men's Schwann that I would like to convert to a geared bike. How do I go about getting parts to do this. Can it be done?
  • Cycling Master
  • 1,237 Answers
It can likely be done, but would not only cost much more than a good used geared bicycle - it involves a lot of skills and tools that you do not possess. Sell the bike and buy a geared bike.
Posted on Apr 24, 2017
  • 4,500 Answers
I am not familiar with the type of bicycle but I assume the bike is currently a fixed wheel type - the type sometimes described as an ash track racer?
The problem when converting will be keeping the frame geometry correct while bending the rear forks to accommodate the wider axle of the wheel with a deraillier gear. It is necessary for the chain wheel to align exactly with the middle sprocket of the cluster.
The best option would probably be to fit a two, three or four speed hub.
Posted on Apr 22, 2017
Schwann 170 exercise bike has no tension
Schwinn bikes with that issue are not worth repairing.
Jan 17, 2018 | Exercise & Fitness
How can I get a manual for my new Schwinn 700c Men's Trail Way Bike S5984TG
Owner's Manuals ' Support ' Schwinn Bicycles
www.schwinnbikes.com/usa/.../owners-manua...
Schwinn Bicycle CompanyGet owner's manuals for Schwinn bikes here. ... Perfect for riders who want a classically-styled, comfortable and simple bike to cruise around town or on the ...
schwinn 700c trail way Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on schwinn 700c trail way related ... I need an owner's manual for 700c Schwinn Fifth Avenue Men's Hybrid Bike,.
[DOC]mens schwinn 700c trail way hybrid bike read expert
104.236.22.177/mens-schwinn-700c-trail-way-hybrid-bike-read-expert.doc
mens schwinn 700c trail way hybrid bike read expert , amazon customer reviews ...schwinn 700c men s trail way , men s 28 inch schwinn zeno hybrid bike ... Vw Passat Alltrack User Manual , John Deere Compact Utility Technical Manual ...
Jan 05, 2016 | Cycling
The chain feels and sounds like it's jumping gears or slipping on the rear sprockets. It does it in all gears. It is a diamondback wildwood large 20"
The rear derailleur needs adjusting, once to establish limits (so it can't go past high gear or low gear). Everything else is up to you fine-adjusting the shifter to make the bike run quietly. If you're careless about your gear changes, you'll get MOSTLY into one gear but not quite perfectly, so the bike is always trying to start shifting into another gear - that's the sound you hear, the sensation you feel. Fine-tune your shifter positions each time you shift - you'll find a "sweet spot" where the bike runs almost perfectly silently.
No, they can't readily do that at the factory, not with chain drives. There are just too many things that can affect gear changes, and things are in a slightly different position every time you remove & replace the rear wheel, or even loosen & retighten it. Unless you're ready to spend vast dollars on a foolproof shifter system, shifting cleanly is going to be your job and your job alone. It's one measure of your bike riding skill... and the better you get at that skill, the better you feel about it.
...and your bike will like you for it.
Jul 30, 2014 | Diamondback Mens Wildwood Classic Comfort...
Mongoose Maxim 26" mens bike-
If it's "broken" or even bent it will have to be replaced. Your frame or derailleiur hanger may also have taken a fatal hit.
You should consult a Bike Shop.
If you still want to DIY you'll need to obtain some specialized tools and skills.
http://www.parktool.com/blog/repair-help/rear-derailleur-hanger-alignment
http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Jul 09, 2011 | Cycling
Bought a Huffy 26inch magellan 700c mens commuter Bike from Kmart there was no manual having trouble figuring out how to get it into various gears, is there a manual I can down load.
just move the gear levers, but keep pedalling forward while you do. you cannot change gears while the bike is stationary and do not pedal backwards while changing
Apr 06, 2010 | Huffy Newport 26 Men s Comfort Bicycle
Engine Monotonous sound from new yamaha gladiator ss 125cc
The sound is being caused by something mechanical. It is not likely to go away by it's self. It will probably get worse. Don't wait for the next service. Take it in now before any more potential damage can be done. Check the oil level in the gearbox. It could be low.
Jan 21, 2010 | 2008 Yamaha Gladiator SS
The bike wil not throlle down when shifting gears
ok buddy basically take the carbs off to do this get back to me once done this
Sep 24, 2009 | 2003 Yamaha V Star Classic
Mens Titan Pathfinder Mountain Bike
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Feb 14, 2009 | TitanNet Bike USA Titan Pathfinder Ladies...
Cycling Logo
480 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
