Question about Garden
My Huskee 17hp Kohler won't start. I found a plug type wire hanging underneath it but, can't see where it would plug in.
  • 41 Answers
SOURCE: Have 2 craftsman riding mowers 42
Take spark plug out ,put sparkplug wire on plug and let it lay against block. Watch to see if plug fires. If not change coil. Hope this helps.
Posted on May 19, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere 17hp kohler
YOU MAY NEED A NEW SEAT SWITCH OR THE PARK BRAKE SWITCH IS EITHER ENGAGED OR IT IS DEFCTIVE.
Posted on Oct 11, 2009
philwalker78
  • 608 Answers
SOURCE: Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Posted on Apr 11, 2011
richroth
  • 9472 Answers
SOURCE: my garden tractor husqvarna model
Take a look at this tip I wrote on the no start problem. It should help you.
Posted on Oct 18, 2011
  • 3519 Answers
SOURCE: Craftsman tractor lt2000 with 17hp Kohler won't start. Ran fine last week. Rebuilt carb, changed oil, and new plug & fuel filter month ago. Has spark and fuel. Cranks but won't fire.
Hi Mike:
It's trying to make you crazy.
I have a model YT4000 and it is a PITA to start when cold.
I pull the air filter, toss in a bit of gas to prime it, and it starts instantly.
I'd suggest that you give yours another try. 3 or 4 times of a couple of seconds each. If it doesn't go, pull a spark plug and see if it is wet or dry. Wet indicates getting gas but no spark. Dry indicates not getting gas.
While you have the plug out, check the spark... Hot & blue.
Hope this gives you some more to work with.
Posted on Jun 22, 2015
Husqvarna 17hp zero turn mower with Kohler engine will crank over but not start. Replaced battery and checked spark plug. Help please!
Out of fuel ? Fuel shut off in off position ! If it's cold where you are any water in the fuel will freeze !
Nov 02, 2014 | Garden
Huskee madel 13af673h131, won't crank
I guess you were sitting on the seat while trying to start the unit, so Try to apply power direct to the starter, if it turns over buy a solinoid. If it doesn't the starter may be bad. To check the engine: take out the spark plugs and try to turn over the engine from underneath by hand, using the pulley. This will tell if the engine is siezed up
Apr 10, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Craftsman lt2000 17hp kohler Has12volts to solenoid and only clicks and doesnt crank. Jumped to starter red cable and starts.
The battery is weak or needs a charge. Have it load tested at a parts store. It needs about 14 volts to start.
Jan 15, 2013 | Craftsman Garden
Kohler 149 cc engine won't start seems to be getting no fuel
This may not fix your problem but it does deal with that engine. I just tried to replace the spark plug in that engine and it took me 5 hours. The Kohler plug in the engine that came from the factory cannot be found in traditional stores and it is a strange size, 11/16 or 12 mm. The Kohler plug is #1413211. I could not find a match in a book. Divine intervention lead me to a place where they were fixing the Kohler 149cc engine that had the same plug in it that mines did. I discovered that a Champion 8815 does fit the engine but it takes a 18mm socket. It did fix the problem and the mower works. Hopefully this will save someone my hassles.
Apr 28, 2012 | Garden
Apr 07, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John deere 17hp kohler
Make sure your electronic ignition (modular, coil, or whatever you want to call it) is not the problem. Check this by replacing old plug with new (I'm sure you already did this), but before putting the new plug in connect it at the top to the ele ign wire, then lay it on the machine or any piece of metal, (screw driver will do) then try to start the engine. Watch to see if you have fire between the spark plug and the metal. If not it is the ele ign that isn't any good and must be replaced.
Jun 14, 2009 | John Deere 42 in. EZ Trak Bagger
Have 2 craftsman riding mowers 42"cut one 16,50 kohler engine/the other 17hp. both have the same symptoms won't start tried plugs primed cylinders with starter fluid also gas, seems like they have no spark...
May 18, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
