Question about Xerox Office Equipment & Supplies
We need to print a custom size in tray 2 using a Xerox 8580 printer and need help with the setup
  • 208 Answers
SOURCE: Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray. Cause:
Extended tray is not set up properly for envelopes. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Enter tools "Login" 1,1,1,1,1 Touch buttons with the following names in that order: System Settings System Settings Common Settings Other Settings Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking" Close out tools.
Posted on Nov 30, 2007
SOURCE: Setting Usier defined paper size
I had the same problem. I wanted to print something on a 8x6, but of course that's not a size option. So, I had to uninstall and reinstall my printer. Then, "magically" a custom button appeared under the size options in the printing preferences window and I was able to change the size for custom 1, custom 2, and custom 3. Gotta love all the headaches, huh? Good luck!
Posted on Dec 27, 2007
  • 26 Answers
SOURCE: PRINTING ON CUSTOM SIZE PAPER
you need to change the page lenght on the printer. to do so...
  1. turn off printer
  2. press and hold the tear off button while turning on the printer
  3. a menu of the setting will be printed
  4. just follow the instruction
  5. you need to set the page lenght for tractor feeding to 8inchs
turn off the printer it willsave the setting
Posted on Jan 11, 2008
SOURCE: Stopping Auto Tray Selection
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
Posted on Mar 10, 2009
RPFinney
  • 385 Answers
SOURCE: Can not figure out how to print on any custom size paper
If you go to your printer properties, preferences or advanced, on the Main menu, is paper sizes,
click the little tab, look at the sizes list,
scroll to the bottom, and you will see.
Custom sizes by User, create your User Defined cusom size.
check your paper tray is setup correctly.
should be good now.
Regards
Richard.
Posted on Apr 20, 2009
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
I need to print standard size 10 envelopes. Where/How do I load them? WorkCentre7335
Some setup will be necessary both on the WorkCenter and in your software. I will describe these steps and leave you with a link to Xerox to check as a reference:
On the WorkCenter 7335
1) In the Bypass tray, load the std. 10 envelopes width-wise with the side to be printed down, flaps tucked in and with flaps entering the printer first. Slide the guide to just touch the edges.
2) Touch <Change Settings> on the WC 7335 screen
3) Select "Envelope" from the "Paper Type" list
4) Select "No. 10 Env" from the "Paper Size" list
5) Select "Save"
6) Select "Confirm"
In your software:
As you did not specify your software, it is important to note that whatever application you are using, the following settings must agree with the steps above:
1) Feed method = Face down, Clockwise rotation
2) Feed from = Bypass
These options may be chosen in different ways depending on your software program.
You may review these setup steps for Word here:
Xerox WC 7335 Print Size 10 Envelope
Jan 25, 2010 | Xerox WorkCentre M118 Laser Printer
About using custom size page setup. 7" x 10". It takes it as B5 setting.
Your printer paper tray paper size is not set properly. Check the paper tray side guide and make sure it is adjusted properly to size of the paper you are trying to print. If this is a printer go to print property or printing preference and select the paper size. I hope this will help you solve the problem.
Apr 20, 2009 | Computers & Internet
I am too stupid to print an envelope
No, your not. The M24 has to be the hardest machine on earth to print an envelope on, It is the biggest headache I have ever seen in printing. Here are the instructions and good luck.
NOTE: The PCL driver is the only driver supported for printing envelopes. There is no support for printing to envelopes using the Adobe PostScript® printer driver. It is necessary to complete all steps to successfully print envelopes.
NOTE: If printing through a server, changes to the driver must be made at the server level.
To set up the custom size paper for the printer:
NOTE: The setup of the custom size paper is a one-time step. Once the custom size is setup it remains an available paper size until it is changed.
  1. At the workstation, click on [Start], point to [Settings], then select [Printers].
  2. Right-click on your printer and select [Properties] from the menu. The Printer Properties window will be displayed.
    NOTE: Use the custom size paper in the printer driver when printing within an application.
  3. Select the [Configuration] tab.
  4. Select [Bypass Feed Orientation] and make sure it is set to Portrait in order to feed the envelopes long edge feed (LEF).
  5. Select [Custom Paper Size].
  6. Select one of the five custom sizes.
    NOTE: There are five custom sizes that can be set up for use in the printer driver properties. Custom Paper Size can be given an individual name by selecting [Name]and typing the name for the custom size, such as, envelope. The name will then appear as an option in output size.
    Three types of envelopes are supported:
Type for Envelope Metric Size Imperial Size Monarch 98.4 mm x 191 mm 3.9 x 7.5 Inch Commercial #10 105 mm x 241 mm 4 x 9.5 Inch DL 110 mm x 220 mm 4 x 8.6 Inch
  1. Enter the short edge and long edge values for the envelope size you are using. The driver will now show the new custom size as one of the choices in Output Size.
  2. Click [OK].
To set your printing preferences for the printer:
  2. Right-click on the printer you want to print envelopes and select [Properties] from the menu that will be displayed.
  3. Select [Printing Preferences].
  4. Select [Tray 5] (Bypass) for the Paper Source.
  5. Select [Heavyweight 2 (170-220 g/m²)] for the Paper Type.
  6. Select the custom size you created for envelopes for the Output Size.
  7. Click [OK] twice to exit the Printing Preferences and the Properties windows.
To print envelopes at the workstation using Microsoft Word®:
  1. Open your Word application.
  2. Select [File] on the top left of the toolbar.
  3. Select [Print] from the menu. The Printer window will be displayed.
  4. Select the printer that you will use to print the envelopes. This printer will use the same driver where you defined the custom paper size.
  5. Select [Close].
    NOTE:If you do not select the correct driver you will not be able to select the correct paper size in Page Setup.
To print envelopes at the workstation using Microsoft Word Page Setup:
  3. Select [Page Setup] from the menu. The Page Setup window will be displayed.
  4. Select the [Paper Size] tab.
  5. Use the paper size pull-down to select the paper size you defined in the driver. The paper size will be listed by the name you gave it in the driver setup. The default will be custom 1, 2, 3, 4 or 5.
  6. Make sure the orientation is set to Landscape and select [OK]. At this point edit the page with the information you want printed on the envelope.
  7. Select [File] from the toolbar.
  8. Select [Print].
To load envelopes at the printer:
Load the envelopes into Paper Tray 5 (Bypass Tray). The orientation needs to be long edge feed (LEF) with the flap closed and the flap side at the lead edge, and the print side facing down. The printer is now set to print on the envelope.
NOTE: Load a maximum of 10 envelopes into Tray 5 (Bypass Tray) at a time. You may be able to fit a few more depending on the envelope's thickness but do not exceed the max fill line on the tray. The envelope may wrinkle depending on its weight and stiffness. The machine is not designed to handle high-capacity production envelope printing.
Feb 09, 2009 | Xerox WorkCentre M-24 Color Copier
Envelope printing
The manual bypass tray on the Phaser 8400 can be set only when you have paper in the tray.
The envelope will read in the set up when you have it in the tray.
Nov 12, 2008 | Xerox Phaser 8400 Laser Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Some thoughts.
Nov 22, 2007 | Xerox WorkCentre Pro 123 All-In-One Laser...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
