Question about Sewing Machines
My tension discs will not stay tight. The screw will not catch the threads on the post.
  • Sewing Machines Master
  • 12,042 Answers
You might try this.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point (will probably need to tweak this for your particular machine).
Posted on Apr 22, 2017
I am using a Juki DDL 8700 thread to tight & not pulling through needle & cactching bottom thread
needle too small or machine out of time. to time machine theres a mark on needle bar. lower needle bar till mark shows and raise bar till even with bar guide. take off feeder plate so u can see needle in relation to hook. when mark on needel bar is even with bar guide the hook should be 1/16 fron passing the needle. if not loosen 3 screws and trial and error it to get it right. use a small screwdriver and tighten just on screw when u hab aglined the hook to needle. do a full rotation and watch where needle is and needle bar mark. needel should be as clost to hook without touching.
Dec 30, 2014 | Juki DDL-8700
Why is the thread catching on the tension discs on my Singer 5430C machine
Have you cleaned your discs lately? Thread has wax applied to it believe it or not. Take a sturdy piece of cloth, fold it over and "floss" the tension discs. Test the stitch again. If that does not solve your problem, then the discs themselves may need replaced.
Aug 24, 2012 | Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
..the right needle thread keeps coming out and I
Sounds like you have a tension problem. Have you re-threaded? Check tension discs for bits of broken thread which may cause jamming. The thread must be catching somewhere. Pull it through by hand to see if it is too tight.
Mar 24, 2011 | Janome Harmony 9102D Mechanical Sewing...
How do you tighten the tension for the thread?
Top tension on most machine is adjusted by turning a tension knob in front of two discs this holds the thread tight. bottom tension is uasually adjusted by turning a very small screw on the bobbin case were the thread comes out from under.
May 20, 2010 | Sewing Machines
Old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Aug 29, 2009 | Bernina Sewing Machines
Bobbin thread is catching on bobbin case
Could be a few things: 1) the tiny screws that adjust the thread tension may have loosened, or even tightened. 2) the bobbinnitself is not wound well. Place the bobbin in the case, and gentlpull on the thread, if it is too loose, it will cascade out quickly. if too tight, it will give resistance when you tug on it. he little screws on the case will either tighten or loosen the thread tension on the bobbin. Make sure that when you re-engage the case, the bobbin fits al the way into the machine. You should here a little "snap" when it fits all the way in. Also, check to see if the bobbin has too uch thread, making ithard to put all the way in the case.
Mar 24, 2009 | Husqvarna Viking 1
Thread won't stay in discs and under tension spring
On the first set of spring loaded tensioner plates there is a small bar that comes out straight at you. Bring the thread over this bar before heading down to the next catch. Also make sure you do not have dirt in between the plates. The only other possibility is the tension release is easing the thread tension while sewing. (like your knee hits the foot lift or the whole foot lift is too tightly assembled
good luck
May 21, 2008 | Consew 206RB
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
