Question about Garden
I winterized my fx541 walk behind bob cat mower went to start and will not do anything I put new battery and new gas but will not do anything when you turn key on ?
  • Kenneth moore
    Kenneth moore Apr 22, 2017
    How long does it take for a answer
SOURCE: Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Posted on Mar 18, 2009
SOURCE: My swisher pull behind was working fine and I was
take the cover off above the ignition switch ckeck 4 loose wires if nothing is found wrong jump it at the selinoid if it starts go to the nearest perts store and buy a selinoid for an ole ford truck transfer wire exact and it should wrk fine
Posted on May 07, 2009
  • 127 Answers
SOURCE: Craftsman 5.5 Gold mower will not start
YOUR PROBLEM IS SIMPLE.
FIRST OF ALL THE HOLE IN THE PRIMER BUTTON MUST BE THERE TO POP BACK OUT EACH TIME YOU PRESS IT NOW AS TO THE GAS COMING OUT OF THERE
THE FLOAT IN THE CARB IS STUCK IN THE FILL POSITION AND WILL NOT LIFT ONCE THE BOWL IS FULL TO STOP THE GAS FROM FILLING OR YOU HAVE A PIN HOLE IN THE FLOAT ITSELF.UNDO THE NOT ON THE BOOTM OF THE BOWL WITH THE LAWN MOWER TILTED ON A 45 DEGREE ANGLE SEE IF YOU CAN MOVE THE FLOAT UP AND DOWN IF IT IS FREE MOVING SPRAY THE WHOLE AREA CLEAN WITH CARB CLEANER AND REASSEMBLE TRY TO START ,IF STILL THE SAME PROBLEM YOU WILL NEED TO REBUILD THE CARB AND INSTALL A NEW FLOAT
Posted on Jun 26, 2009
  • 6 Answers
SOURCE: Black and decker cordless lawn mower CMM1200
i had the exact same problem and i went into the hand switch box (the box on the handle with the lever attached to it) and cut out the safety switch and then took the two wires that were on the safety switch and soldered them to two poles of a heavy duty toggle switch. That fixed the problem for that year but one year later i.e. now, theres another problem with the mower and i can't figure out what it is. I have broken this thing down to the smallest parts and still can't figure out what is wrong. Bottom line try to fix it with the switch solution but don't buy another one. BLACK AND DECKER SUCKS!!!!
Posted on Aug 06, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
Craftsman lawnmower won't start after winter storage
Try to put a little gas in the sparkplug hole.Put plug back in then try to start again.
Feb 20, 2015 | Craftsman Garden
Where can I find a troubleshhot guide for a lawn-boy cordless walk power mower model 10123
Batteries need to be kept warm and charged,on a regular basis,this is where a "Float Charger" comes in handy to monitor battery voltage while in storage ,I'd bet the ranch your battery is toast,but any auto parts store could LOAD test it for you ,Good luck !
Jun 08, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Scag tiger cat wont start
I would put new plugs in change the oil put a new in line gas filter in. After this tune-up check for spark by leaving the plug out on the moter body crank it over if the spark is hot you know its a gas problem also check for any grounding by starting it at night then looking around to the engine to see if its grounding out. Try these simple things. Do not change anything on the moter without doing these things first. Good luck
Apr 11, 2014 | Scag Tiger Cat 52 Zero Turn Mower...
Water Mixed With Fuel in Mower
You got the bulk of contamination out of the tank. The lines will burn off. Try a higher octane gas. Drain any visible lines.
Mar 12, 2014 | Toro Garden
Craftsman Snowblower Won't Start
If you did not put gas stabilizer in your fuel tank when you stored your machine the gas will turn into varnish. Try draining the gas and put new gas and try to start it. Good luck
Jan 04, 2014 | Craftsman Garden Tractor Snowblower...
The riding mower has been used in June. Now when I try to start it I cant. I have checked the battery, gas, etc. before trying to start it. What can I do now?Thanks
put gas right into the carburetor and see what happens. if it doesn't do anything then you have a spark issue, if it runs until the gas you just put in runs out then it is a carb issue. sometimes just priming the carb with gas will get it to run again too
Sep 25, 2013 | Ariens 21 In Classic Walk Behind Push Lawn...
My push mower will start good but wont stay running..could gas that was left in it over the winter be the problem or just the wrong kind of gas
does it have a fuel tap or not, if it doesnt then the fuel that was left in the carby has gone to jelly or harder ,a carby service should do the trick and save you money in the long run
May 15, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
