Question about Boating
Tohatsu 15hp 2 stroke outboard. Approx 10 years old. Starts fine, revs fine and idles when in neutral.
But on engaging forward gear, the engine would not accelerate past approx 1/4 of throttle, added to this a stuttering sound from the outboard, and the same in reverse. Any ideas for me to try?
SOURCE: I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke
all 3 carbs had A  clogged jet totally dis assembled and cleaned the carbs put them back on and the engine runs great I will need to fine tone the needle valves once I put some fresh gas in it.
Thanks John
Posted on Jul 09, 2009
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
goldbill
  • 184 Answers
SOURCE: tohatsu outboard 15hp 2 stroke was running great,
First: with flashlight or mirror look down the carb- with switch off- and gear and throttle wide open and see what the butterfly valve inside there is doing. It should be parallel to the air flow.
If not you need to find the actuator am and be sure it moves with the control and opens all the way.
Next make sure the timing plate under the flywheel moves at the same time the throttle is opened. Then -using timing light- see if the timing is set to the correct "wide Open throttle" - this is a 2 man job done at sunset with good marks on the flywheel (don't wear a tie). This can also be done static by running it out of gas and using the pull cord- if it has no safety interlock.
Last- and the saddest part- is the compression test. The strength of the reading is not as important as the similarity. When I worked on Chryslers, they were bad if the two readings were as little as 8# apart. The minimum reading should be over 80#.
Posted on May 26, 2011
  • 107 Answers
SOURCE: 2006 Honda CRF 100. Running good,
The carb jet needle clip position controls partial throttle conditions. If it hasn't been moved from it's stock position, the needle is probably worn and should be replaced along with the main jet and the e-clip put back to the stock position. It's really hard to see if they're worn because the parts are so small. They're cheap parts and the fix is pretty simple so good luck!
Posted on Jun 12, 2011
Testimonial: "Great advice! Really helpful! Thanks"
Mikew515
  • 28 Answers
SOURCE: 2009 Buick Lucerne won't accelerate. Engine just revs.
Sound like bad transmission. Will it go into reverse?
Posted on Feb 28, 2014
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Have new tohatsu outboard that runs fine but wont rev out over 4500 rpm
I just looked at 7 different sites and they are saying Max RPM is between 4,500 - 5,050... How accurate is your Gauge?
Prop Pitch will greatly effect MAX RPM.
Apr 05, 2013 | Sierra International 18-6431 Marine...
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
Ignition issues
could be a hole in fuel pump diaphram
Dec 11, 2009 | Light Outboard Motor Boat Bass Fishing...
Aug 22, 2009 | Boating
3.5 mercury outboard stalls when put into forward
hi take the prop off see if there is anything /string/ between the hub and the housing check oil lvel in g/box /is gear box nice and free if all is ok try it in ware with just a small amount of choke
drain /empty fuel out replace with fresh /correct oil mix
check /change fuel filter/air filter
warm engine up check idle mixture ajustment/tick over speed
increase idle speed slightly/7/800 rpm
hope this helps merlin v 12
Aug 20, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke engine starts and runs fine in neutral try to accelerate under load and it only will pull about 2800-3000 RPMs and wont go any faster it will rev fine in...
Reving in neutral does not mean the same thing as under load. If you need to pull 4500rpm under load and for an instant the load was gone, you would probably overrev to 6500. With the cover off and motor not running move the throttle to full forward. Look at your carbs and see if the throttle plates are wide open. If they are not all wide open take it back to the dealer. The throttle adjustment is off. You need the full range of travel from idle to topend.
Jun 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Engine stalls when engage in any gear from neutral.
CHECK THE SIDE STAND SAFETY SWITCH IS OPERATING
Mar 19, 2009 | 2000 Suzuki GSX-R 750
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
