Question about Ovens
Need help with wiring a switch on Westinghouse Stove model BD-74.
I have the switch, but the repairman was unwilling to install it because the wiring diagram on the back of the stove was unclear. He did install another switch which works.
  • 126 Answers
SOURCE: Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Posted on Dec 14, 2007
SOURCE: Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Posted on Jul 21, 2008
VtToolMan
  • 704 Answers
SOURCE: I need to change my oven ignitor and I need a diagram
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Posted on Jul 31, 2009
SOURCE: Electric Diagram for Kenmore Model 790
I have a Kenmore Model 790.91062601 and it has stop heating. None of the burners or the oven will heat. Any solutions
Posted on Aug 30, 2009
SOURCE: I have a caloric heritage series gas stove in
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Posted on Jan 04, 2010
My Westinghouse 688 oven light was not working. Replaced globe and still not working. Is there something else I can do or is this now a job for electrician? Thanks Pam
many times it will be the bulb socket or the wires going to it .take the back off the stove and look it over real good
Aug 10, 2015 | Ovens
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
Westinghouse 668w
Sounds like you are only getting half the power to your stove, first check your breaker for the stove,turn it off and then on again,one side off the breaker may not be making a good connection giving you only 110v instead of 220v which is why you will have lights and no heat. If that does not solve the problem and you are comfortable working with electricity shut off the breaker, unplug the stove and remove rear access panel where the cord goes into the back off the stove and make sure all 3/4 wires are securely connected, that being done and it still does not work you may have a bad breaker or connection in box or a faulty outlet.
Apr 07, 2014 | Ovens
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
The oven door has disengaged at the hinge I cannot get back into the slot on the stove westinghouse
Hi You cant do this without taking the door off the oven this is a 2 person job when it has disengaged There is a wire clip on the bottom of the K type hinge that hooks on to the top of the hinge if you can get them to hook together you can then remove the door You need to do this to both hinges lay it flat get the 2 hinges hooked together put the door back in the oven and release the hook the hook also looks like a flat u shaped bracket it depends on which westinghouse stove you are talking about as to where it is located mostly it is very close to the oven itself Regards Geoff Stove Recyclers
May 28, 2011 | Ovens
My magic chef rv range will not light the burners with the ignitor. I replaced the ignitor at the control due to the wire prong being broken off. It worked prior to the wire prong breaking off. What do...
hope this helps a little...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/15-104--/Magic-Chef-Stove-burner-won-t-light
Jan 14, 2018 | Magic Chef Ovens
Can i change the element myself on a Westinghouse avondale? Dave
unplug oven and unscrew element from inside oven...pull out of rear of stove...if having problem bring out..the rear panel behind oven can come off to help you...remove wires going to element and re-install on new element and put together
Jan 21, 2011 | Ovens
Hi , i am an electrician installing a westinghouse pek1380w-r stove , my mate that bought the stove is still waiting for the manual and cannot tell me how many amps the stove will draw so i can select a...
this unit will draw up to 50 amps if all burners are operating. i do not know the exact wattage, but they usually have an 8 gauge wiring connector already on the oven, if a wall oven.
if a free standing then you will have to put on a cord that will also be an 8 gauge.
you will need to determine what wire gauge to use depending on how long of a run you have from the circuit panel to carry the load.
it is also a single phase 240 volt system, but that doesnt matter because the wires are the same.
are you new at being an electrician? check your code book to make sure you are doing this wiring by the codes for your area.
Jan 12, 2010 | Ovens
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
F 10 Error code
I was unable to find an F10 fault code for the model you provided.
Have you checked your users manual?
Below is a link to most manufacturers fault codes. It also provides links for parts and exploded view diagrams.
It appears that your model was made by Westinghouse but their F codes only went to F8.
http://www.repairclinic.com/0078.asp#Westinghouse
Let know if the information I provided helped solve your problem by rating my answer.
Thank you,
Dave E. (Illeagle)
Jun 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
