Question about Building Materials
The garage door will open but will not close - Building Materials
  • 927 Answers
Check to see if the safety sensors (located about 6 inches from floor on both side of door). One will always be on and the other will be on when the beam from the other sensor is unobstructed, or misaligned
Posted on Apr 23, 2017
Why would a Craftsman model 139.53985DM garage door opener not open when it is cold outside?
Safety light issue. Blocked beam. Misaligned beam. Or broken wire.
Mar 03, 2015 | Building Materials
Linear garage door opens and closes when close to unit about 10 '
when the door stops moving when going down, pull the emergency release handle on the door and then push the door closed by hand. Once it's closed push the emergency handle back so it engages the chain. Open the door and close it a few times to make sure it closes all the way with the motor.
Oct 01, 2014 | Linear Corporation Linear Garage Door...
Craftsman 1/2 H/P garage door opener door goes closed but then opens
Try adjusting the "closed switch" forward a little in case the door is going too far when trying to close.
Sep 03, 2014 | Building Materials
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Installed garage door opener and the door opens then closes on its on
The down limit switch could be set to low. Try moving the screw clockwise to raise the stop point.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
115 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
