Question about Panasonic Office Equipment & Supplies
My panasonic PTD 6000 projector doesn't startup. The lamps go on, but no menu access, zoom or anything else. The only thing i can do is power it on or off, and operate the shutter. can I fix this?
Marrie
  • 563 Answers
SOURCE: RESET LAMP HOURS
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
Posted on Apr 01, 2008
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
  • 4234 Answers
SOURCE: cannot access menu screen on Panasonic PT-D3500U projector
If memory serves me correctly, there is an OSD button on the projector itself. Press that once. You may have turned off the OnScreen Display feature. If that fails to resolve the problem, please let me know and I'll look up your specific model.
Dan
Posted on May 28, 2008
quang123
  • 107 Answers
SOURCE: Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Cheers
Posted on Jan 15, 2009
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
How to check lamp timer
Bulbs do not really have a certain lamp life they only have a lamp timer. You will want to be sure you can get a replacement lamp they can go anytime between 0 and 6000 hours.
Apr 22, 2013 | Mitsubishi SL2U Multimedia Projector
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
I have replace the lamp but any how i am not getting any response from projector. As after replacing the lamp projector was ok. It shows all the thing but second time. No response. pl suggest
hi,
you didn't mentioned any thing about the indications. is there is any indication on the projector. if projector have some problem it will show the indication for the same using its self diagnosing system.
just do one thing check the power cable and the power at the socket to which you have connected the projector. if these are ok and the projector have no indications on its panel, then the smps power supply in side the projector have some problem. if so it is difficult repair the smps by the user. need good knowledge of electronics servicing, because there is harmful high voltage points.
Is there is any indication on its panel, then if you discribe the same will provide you the exact solution .
Also try to check the inserted new lamp , lamp cover is it properly closed etc.
if the projector starts try to reset the lamp hour
1. Go to its menu select option2
2. From the option 2 menu select lamp runtime
3. Press and hold the enter button for approximately 3 seconds
4. After resting just power off your projector and turn it on again.
Also check one more thing
The "CONTROL KEY" may be set to "OFF". In order to set the "CONTROL KEY" to "ON"
without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
ok
Apr 04, 2011 | Panasonic Videoprojector PT-LM1E...
My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
resetting procedure.
1. inset the new lamp.
2. power on the projector.
3. Press menu and select OPTION.
4. Press enter button and the select LAMP RUN TIME.
5. Press and hold MENU button for 3 seconds.
6. Lamp reset , power off message will display.
7. power off the projector. this will reset the lamp hour.
Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT LC76U Multimedia Projector Lamp how do i reset the timer
press the MENU button to display the menu screen, and then press the UP and DOWN aero button to select the "OPTION" menu. press the ENTER button and then press the UP and DOWN aero button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" screen will be displayed.
(NOTE: press any button other then the POWER button to cancel the "LAMP RUNTIME" screen)
Press the POWER button to turn off the power.
The POWER button on the projector illuminates red.
This will reset the cumulative usage time for the lamp unit to "0"
Jan 12, 2011 | Panasonic PT LC76U Multimedia Projector
What will I do to reset lamp timer for my Panasonic PT-AX200 model
Read very carefully this is the only solution to reset lamp timer
1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
3. Press the MENU button to display the menu.
4. Select the OPTION menu and press the ENTER button.
5. Select LAMP RUNTIME.
6. Press and hold the ENTER button for approximately 3 seconds.
7. The confirmation screen will be displayed and select OK.
8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
Jan 06, 2011 | Panasonic PT-AX200 LCD Projector
How do I reset the lamp hours on the Panasonic LB20u projector.
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 25, 2010 | Panasonic PT-LB20U Multimedia Projector
May 25, 2008 | Panasonic PT-F100NTU LCD Projector
Panasonic PT-L557U Bulb Life
lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
27 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
