Keep getting a E04 message the last 15 minutes of rinse cycle. Have found no debris from clean-out to end of drain hose. Am using less soap in case of suds and nothing works.
jsrock516
  • 5911 Answers
SOURCE: Suds Suds Suds
The SUDS fault indicator is caused by using too much detergent, or the wrong type of detergent. The Kenmore Elite front loaders were designed to use HE type detergent only. When the washers first came out, manufacturers originally made the claim that you could use regular detergent if you used less of it. The manufacturers later retracted that claim because there were a lot of problems with over-sudsing. If you are not using HE detergent, you need to be. In the mean time run your machine with no load with hot water to clear the drum and drain lines of any soap residue. You may have to do this a couple of times to clear the problem. I hope this helps.
Posted on Apr 29, 2007
SOURCE: E04
Perhaps try opening the round panel on the front of the machine at the bottom and cleaning that hose...good luck because it might be messy.
Posted on Nov 22, 2007
textonor
  • 130 Answers
SOURCE: bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
Posted on Jan 23, 2008
  • 135 Answers
SOURCE: the dishwasher was full of soap suds but most of the water drain
Suds? If you use dishwashing detergent you shouldn't get suds. If a small amount of sink type dish soap is left on a dish before loading it into the dishwasher this can happen. I would use several rinse and drain cycles with the racks and dishes removed until the suds are gone.
Never use any type of liquid dish soap made for sinks. The same thing that makes suds in the sink will make even more in the dish washer.
Hope this helps!
Posted on Feb 15, 2009
Macmarkus
  • 2605 Answers
SOURCE: F02 Error Code on Kenmore
Hello, welcome to FixYa.
Based on your information posted I understand you have the Kenmore HE3t washer, correct ?
Reading your description and factoring in all you've done and inspected, it may in fact be a faulty pump...(the F02 ultimate worse case) even if it is draining slowly it does not rule it out, trust me I've seen many of them.
By reading your post I've gathered you are pretty thorough so I don't expect you missed it, but I must mention it or I wouldn't be thorough either, I think you can appreciate that, have you checked the back-flow/check ball ?
If not, here's how...
Pull the boot off if you have not and just see if anything has got in there to obstruct the "ball" from working correctly. It is shown here...(this is from the back, but you can do it from the front...just not as easily...in my opinion)
Undo the clamp and inspect inside...if you have not already.
It's amazing how often I find this ball "stuck" or the bellows clogged with debris of all sorts of items...definately worth looking into before declaring the pump has failed. Good luck. Let me know how you make out as I said and if I can help you in any manner going forward I will do whatever I can.
I've also included a more thorough link of my repair tip below
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Regards,
Macmarkus :)
Posted on Sep 11, 2011
How do i address a recurrent suds display and subsequent extended rinse cycle on my washer? I have tried using less soap ans always use HE soap. Thx
Unhook the water hoses at the wall and check to make sure the screens are free of debris. The pump is easy to access via the back panel--just two screws. There are blogs available that tell you how to check and replace the pump if necessary. Read all of them before you start. It is often the culprit. Good luck.
Dec 13, 2014 | Maytag Neptune MAH5500B Front Load Washer
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
Water leaking through air vent and estimated time remaining sticks during the rinse cycle
Run a tub clean cycle. No clothes. No soap. Just vinegar. About a cup.
May 03, 2017 | LG Washing Machines
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Dec 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Will not drain the last 2 minutes and spin
Clean out filter, Check drain hose at sink, Could also be small coin partly turning within drain hose,, Good luck
Oct 04, 2009 | Washing Machines
Tub has a sour smell &does not seem to be rinsing soap out of clothes
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 29, 2009 | Washing Machines
Bosch frontload washer will not drain
Hope this helps.
Jan 22, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Control Module?
Sounds like a dishwasher.. You didn't say or give a model number. Dishwasher that do not drain are usually caused by clogged up drain hoses, often right where it connects to the drain or disposer under the sink. In some cases, there's a separate drain pump that is defective, in other cases, there's a drain solenoid, and in others a drain impeller that's broken or clogged. All depends on the model.
Oct 24, 2017 | GE 24 in. PDW9880LSS Stainless Steel...
E04
Nov 19, 2006 | Bosch WFMC 2100 Front Load Washer
Open Questions:
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
