Technotech ide dvd writer not compatible with my athplone 1800 PC. Any advice to load it's drivers
SOURCE: blank dvd crashes pc
the drive may be bad the burner software may be corrupted you power supply may be bad (line-in to DVD writer) The IDE (ribbon) cable may be loose
Posted on Sep 19, 2007
  • 1342 Answers
SOURCE: DVD Writer not working
Make sure the jumper on the back of the new drive is set the same as the old one. EXAMPLE: Slave, Master, Cable Select
Posted on Jun 13, 2008
SOURCE: dvd writer for dell gx270 mini tower
If you can think and look logically, you will be able to replace your current drive with a standard notebook drive, mostly called slimline.
open the case by pressing the two knobs at the side and lift it upwards. The unit clicks out easily, the removal of the flat cable and power connector needs a bit of patience, and you have to unscrew the drive from the bracket after that. I think you can get a drive for some $50,-5015338.jpg
Posted on Aug 21, 2009
  • 468 Answers
SOURCE: primary IDE port does not work. My main hard disk
It is Biostar
Posted on Oct 12, 2009
  • 2351 Answers
SOURCE: Replaced IDE DVD writer with a SATA DVD writer.
Check your bios settings. If you already have two SATA hard disk drives in your system the bios should also list your SATA DVD writer as third in the list. Make sure the bios list the DVD writer. Remember all SATA drives including SATA DVD drives are all seen as Masters. Check your Boot order settings as well. If windows sill does not list a drive letter for your SATA DVD click, Start/Run and type: diskmgmt.msc in the run window. Assign a drive letter to the drive manually.
Posted on Oct 23, 2009
Dear Experts, I have connected an internal LG GSA 4163B DVD Writer to my Lenovo Netbook via an IDE to USB cable 2 days ago. Although I could get a new E: drive, a message always popped up complaining...
Sounds to me your trying to do what i did and did not work. the issue is the netbook is not compatable with this method you need a netbook compatable External unit is what i suggest, if there are any experts that have diffrent advice I welcome it as well. But I tryed what your doing in fact i went out and bought a external unit because of this fact, the issue is compatability.
Oct 12, 2010 | LG GSA 4163B DVD±RW Dual Layer Burner
HI i Have a acer aspire T-180 .Am looking at purchasing a dvd Writer fr it but am asked if its Sata ot Idu do you know which is compatible ?.thanks
The dvd rom will IDE not sata, it will be possible to put a sata dvd-r in the pc but you will have to make sure you have the right powwer connector on the power pack for it, your best bet would be to use an IDE dvd-r and add it to the slave connector on the IDE cable already in the pc. hope this helps.
Aug 13, 2010 | Acer Aspire™ T180 PC Desktop
LG. DVD writer IDE serial no. 810HWTF532897 cant play video, dvd or any film
Update your drivers
go to manufacturers site and download them,
The model of you machine should have compatible drivers that will work too
check them first,you will need your model and make and Operating System too.
Cheers Misterdj
Mar 25, 2010 | Computers & Internet
Primary IDE port does not work. My main hard disk drive and DVD writer drive are connected to the Secondary IDE port. If I move them to the the Primary IDE port, both the drives do not get detected at all....
Good day sir, there are several way to connect an extra IDE if the motherboard is full:
  1. Buy a PCI to IDE/SATA card. Check your local computer dealer if there is available.
  2. Buy an external USB to IDE Hard disk enclosure.
Of course, these are things to buy, but check first the CMOS setup if the Primary IDE is enabled on your PC.
Oct 12, 2009 | Intel D865GVHZ Motherboard
Is it compatable with my desktop pc?
Ok. Well basically CD, DVD and Hard Drives are all cross compatible platforms so you don't have to worry about compatibility issues. If your asking me to choose I would say that you remove the CD writer instead. But before you do this make sure you have enough extra sockets in your motherbaord to plug in your Pioneer DVR-1910LS 20x DVD±RW IDE Drive w/LightScribe if your CD Writer uses IDE interface your inluck coz you can use it in place of the Pioneer DVR-1910LS 20x DVD±RW IDE Drive w/LightScribe, but if it isn't make sure you have a spare IDE socket in your motherboard. Simply remove the side panel use a flashlight and see if there are vacant IDE sockets, it's usually long in black, white or blue color. see the picture below.
If its vacant follow the steps on the link below simply copy and paste the link on you browsers address bar.
I hope this helps you...
Jan 22, 2009 | Compaq Presario S6300NX PC Desktop
Any DVD Read writer will work
Jan 01, 2009 | Dell Dimension 3000 PC Desktop
Blank dvd crashes pc
Sep 19, 2007 | Computers & Internet
Blank DVD Causes PC Reboot
if the pc reboots, then a driver or hardware fault is the cause, try uninstaling the dvd drive in device manager, then restart pc to install it again, or if you are able connect the dvd drive to another ide cable connector incase its a fault from the motherboards ide channel.
Aug 09, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
Computers & Internet Logo
David Payne
David Payne
