Question about Golf
My cart is Par Car Eagle 2016. There was a short in lights that I corrected, but cannot find locate fuse. I need to know the location in the golf cart of the fuse to replace it. Thank You
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
Posted on Oct 18, 2008
  • 512 Answers
SOURCE: my eagle vision radio is not worrking i need the owners manual
check fuse 2 and 13 in the fuse block inside the car
Posted on Dec 04, 2008
SOURCE: need fuse box location in 1997 BMW 740IL
The fuse bos should be int he back left of the trunk under the carpet on the side. Peel back the carpet from the side...slowly and you should find it there.
Posted on Feb 11, 2009
  • 45 Answers
SOURCE: Fuse location/ Cooling fan relay location
The relay for the cooling fan is located on the left side (north america drivers side) of the rad about half way down or near the top (may vary) there may be two relays or one, replace them both. As for the fuse location it should be under your dash (fuse panel) looks like a big silver fuse similar to a zippo lighter, it will be marked in fine print "engine fan".
Posted on May 20, 2009
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
Posted on Aug 19, 2009
My 2016 cart has blown fuse for all lights and turning signal. I corrected the short, but can"t find the fuse.
What year , makeand model? The relay may be bad under the hood in the fuse box.
Apr 22, 2017 | Cars & Trucks
What year is my Harley Davidson golf cart serial number 3B15885H7
Hi, Paul that number goes to a Certified Remanufactured 1977 Harley Davidson Columbia Par Car gas powered 246cc two cycle three wheeled two seater Golf Cart for more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at Good luck and have a nice day.
VintageGolfCartParts com
Harley Davidson Columbia Par Car History Company Name
Oct 16, 2016 | Golf
Par car golf cart wont start
Brian, check valves for proper adjustment, if they are OK then problem could be decompression cam/valve faulty. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How the compression release mechanism works on Briggs and Stratton OHV...
HOW TO ADJUST VALVES FIX HARD TO START Lawn Tractor with OHV Briggs Engine...
Aug 16, 2016 | Golf
Find the year serial nimber A9649-548612 club car golf cart was manufactured
Since 1981 Club Car Golf Carts have positioned their serial numbers just under the glove box on the passengers side of the vehicle. The first two numbers (not letters) indicate the last two digits of the year of manufacture.
On Club Car Golf Carts prior to 1981, you can find the serial number by raising the seat and locating the aluminum, I-beam frame section closest to the batteries on the driver's side of the car. If the serial number plate has been removed, you can confirm it is a 1975-1980 model if it has two brake pedals and one accelerator pedal.
Oct 20, 2014 | Golf
Club car golf cart lights
Wiring, fuse and switch. Check for voltage at switch first, if none, check for a fuse in the circuit. I would suspect a fuse or faulty switch first.
Aug 20, 2014 | Golf
We have a 2002 gas club car golf cart and we need a diagram of the key switch starter and can not find a diagram to show the different colored wire connections
yellow-white accesory
red-green- 12v constant.
generic application colors.
use a voltmeter and a 12v light to verify all connections.
Nov 03, 2013 | Dual Club Car Lester Power Drive Charger...
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Golf Cart; 1988 Columbia par G4S gas wiring
I have no reverse could it be a solenoid the generatoris goog.
Jan 31, 2010 | Electronics - Others
Fuse location for pop up lights on a 1991 Eagle
It should be located in the distribution box, also called the power box. It is a black box loxated under the hood. And you have to remove the cover. Underneath the cover it will tell you what each fuse is for, If for some reason it doesn't it will tell you in the manual. Good Luck
Nov 10, 2009 | 1991 Eagle Talon
Club car golf cart won't start.
i have a 1989 club car 10 amp fuse is under seat in a box under air box should have one screw in center of lid
Mar 29, 2009 | 2002 Chevrolet Avalanche
Golf Logo
285 people viewed this question
Top Golf Experts
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
