Question about Dryers
I own a model HBL3360UC. The element seems no longer to heat, on any setting. Can a DIYer replace this part? Is there a video or instruction sheet to do this?
I own a Bosch built-in oven model HBL3360UC. The element seems no longer to heat, on any setting. Can a DIYer replace this part? Is there a video or instruction sheet to do this?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
It is not advised too many hazards. contact your locate appliance repair service center.
Posted on Apr 24, 2017
Clean lite blinking 7 times then stops I have ck heat coil ,inlet value,door switch,all test ok
Heat circuit problem ohm out the thermistor another way to check clamp an amprobe around wire leading to heating element start machine about 10-15 in should have an amp draw but with 7 blinks doubt if you will get one don't know hoe good you are with a meter as a tech I check the element and thermistor at the control to ensure components and wiring are good but the test points are so small it's easier with needle point test leads also make sure one of the terminals has not burned of the element really hard to explain to a DIYer how to perform all the test procedures there should be a tech sheet on the bottom panel under the dish washer
Feb 16, 2015 | Dishwashers
Have a electric cooker model nut grb6cvk no heat from main oven everything else working
Oven heater element has died. Get the serial numbers etc off the plate on the back or the handbook, go online to appliance spares sites and see if they carry an element. If you don't know how, get a good DIYer or appliance tech to change it. You could get them to check the element for continuity first?
Nov 15, 2014 | Leisure GRB6CVK Electric Cooker with...
How can I find our what the controls mean, the dots on the 6500????
thegreyone_0.jpg I could not easily find an instruction sheet, but I believe that the top knob is the thermostat... rotate it clockwise for higher temperatures and counter-clockwise to lower the temperature. The lower knob controls the number of heating elements. The first dot/dash if for the 600W element only, the second longer dot/dash is for the 900W element only; and the longest dot/dash is to select both the heating elements giving 1500W total output power.
I hope this helps...
Dec 10, 2010 | Lakewood (5500) Oil Filled Radiator Heater
My top oven no longer heats up. I noticed just
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 20, 2010 | Amana AOCD2770 Electric Double Oven
Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Whirlpool GBS277PD Electric Single Oven
Frigidaire dryer drum turns but no heat on any setting
first make sure both sides of the 220 breaker in your electrical panel are in the on possition...if they are remove the 2 heating elements from the back of the dryer(usually 2 screws in each)get new at lowes or home depot..thanks and have a great day
Nov 08, 2009 | Frigidaire GLER642A Electric Dryer
Kenmore Dryer, Model # 11063102100, does not dry.
Does the drum still turn. If so probably just needs a new heating element. VERY easy to replace. Usually instructions to replace on or in new element box or just google instructions.
New heating element would be my first move to repair dryer.
Also, if you use softeners or dryer sheets, Wash lint screen with dawn and soft scrub brush to remove oils and residue (even if it dont look like there is none there there is) to extend your heating element use.
Sep 26, 2009 | Dryers
My kenmore 80 series dryer will not heat. Is it a pilot light or a heating element and how difficult is this to fix on my own?
This seems to be an electric dryer so, no pilot light.
The heating element might have failed or it has a heavy current fuse that has failed.
There aren't many things that a dedicated DIYer can't do given time, a few common tools and some common sense.
Having a multimeter at home helps too; these can be had at electronics or auto parts stores and usable instruments can be had for <$20 US. Somewhat intelligible Chinglish instruction sheet is included.
Jan 09, 2009 | Kenmore 65924 Electric Dryer
Smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Dryers Logo
26 people viewed this question
Top Dryers Experts
