Question about Plumbing
Sumps got a liberty 403 ejector pump hooked to slop sink, vented & drains to water waste line. works well used rarely, recently after 18 snowmelt & rain it stopped going on, leaks from top & smells.?
    Novelist:
    Champion:
  • 243 Answers
First check and make sure you have power to the pump. If you do have power, either your float switch is bad, or it is hung up somehow preventing the float switch from rising when the water rises. Remove the lid, and check to see if everything moves freely. After determining that the float is free, grab the float switch, raise it manually, and you should hear the pump turn on. If it doesn't turn on, replace the switch.
Posted on May 03, 2017
Sump Pump Ejector line (outside) freezes.
IF the drain on the outside of the home is in the ground and is not below the freeze / frost line, it needs to be changed. If the drain is above ground at any point it needs to be unhooked at the point it exits the structure and diverted to the ground with an elbow. A splash diverter would be placed under the elbow.
Jan 09, 2018 | Washing Machines
Frozen sump pump ejector
what part of the world do you live in
Jan 12, 2014 | Washing Machines
Dishwasher want drain .what steps should i take to unstop the drain lines
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Sep 02, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Wont drain
Jun 19, 2010 | Maytag PDB4600 Built-in Dishwasher
Wont drain
Apr 28, 2010 | Bosch SHU5316UC Dishwasher
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
My pump won't turn off
If the sump (where you catch the water) was dry, your pump might be air bound.
You say it will not shut off but you dont say if it is pumping. My guess it is is not. You have a local switch, i.e. integral to the pump, right? Not a float switch.
Do this, fill the sump, make sure the switch opening is clear (it works on water pressure) and make sure there is no air trapped inthe pump housing.
I hope this helps.
In my bar situation, I use a float switch and I pump up about 2 feet where the water goes into a stand pipe equipped with a vent. The stand pipe feeds into a hose and leads to a sump elsewhere in the basement where the water is pumped over the side (sorry, that was the sailor in me coming out).
Feb 21, 2010 | Lincoln Lubrication 917 Heavy Duty...
Water wont drain from dishwasher
Dec 26, 2009 | Magic Chef CDB6100 Built-in Dishwasher
Water isn't draining.
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Thanks for contacting fixya.com
Nov 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Installing lift station. have 30 gal sump bucket
Depending on local codes, you may need to vent a 2" line separately out the roof. Otherwise, you may tie this vent into the other house vent line, but it should be a 2" vent conected to another 2" vent line. Again, you will have to check local codes. The drain connection should be made with a 2" connection into the top of a 4x2" wye 10' from any other connection. This follows most plumbing ordinances.
Nov 10, 2009 | Plumbing
Plumbing Logo
641 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
