Question about Sonicare Health & Beauty
I can't seem to get my sonicare to turn on. Do I need to replace a battery?
It's a sonicare flexcare platinum
Why is it making a loud noise after reacharging,never before
Are you sure the brush attachment is "tight" to the handle? Do you have a new brush to try? It should confirm handle is bad or it is the brush attachment "tightness" .
Mar 11, 2015 | Sonicare Phillips Philips Sonicare...
My sonicare toothbrush starting beeping during the night and kept beeping.
Probably two reasons for this. 1) the contacts at the base of the brush are not clean which will prevent proper charging , the low battery beep is telling you to recharge.2) the battery needs replacing.
Sep 23, 2014 | Sonicare Philips Flexcare+ with UV...
I am currently using the electric Phillips toothbrush. Would like to change the batteries but having problems removing batteries with all the glue. Did not want to damage circuit board. Need more...
Take a look at this video from YouTube; hopefully it will help you to remove the battery from your philips toothbrush.Good luck
Feb 10, 2013 | Sonicare Phillips FlexCare RS930 / HX6932...
Phillips sonicare toothbrush keeps turning on by itself and function lights stopped working
My flexcare began randomly turning itself on about a week ago. When charging it would vibrate a pattern of one short, then 2 short bursts. After talking with tech support and finding my flexcare was out of warranty, fixed it myself.
I opened the the base with a flat head, disconnected the battery (my model did not have a soldered in one) and wiped out the condensation in the housing and on the brush. I put it back together and it works as before. YMMV
Jul 10, 2012 | Health & Beauty
Philips sonicare essence 5500 doesn't stop blinking
Turn it on and put it on the charger while still on. This should turn off toothbrush. And it stopped the blinking!
Dec 11, 2011 | Sonicare Philips Essence 5500 Toothbrush
My sonicare toothbrush won't charge
The best tutorial for repairing Sonicare toothbrushes is here:
Repairing your Sonicare
The problem is either a corroded circuit board or worn-out Ni-Cad batteries. Both repair solutions require soldering, but full repair is possible.
Sep 30, 2011 | Sonicare Philips Essence 5500 Toothbrush
I have a 2004 PT Cruiser Platinum series with a 2.4 liter engine, wjhat is a suitable replacement battery for this car; Sears die hard or interstate ?
Sears Diehard or Interstate would make a battery for your vehicle. Look for something with over 600 cca and you should be ok for the winter.
Diehard makes a Platinum battery, but it costs over $189.99.
Diehard Gold batteries are like $109 or so.
Walmart sells batteries that are comparable to the Diehard Gold for under $100.
However, I just bought a Platinum battery for my 1997 Cadillac Deville Limo and it seems to work alright so far and has a 4 year free replacement warranty.
In general, the more you pay, the better the battery up to the 'best' which is the Diehard Platinum.
Walmart and Interstate do not offer a battery that has as long of a warranty or as good of a design as the Platinum from Diehard which uses proprietary technology to get a better warranty than normal.
The Platinum name in the PT Cruiser has nothing to do with the Platinum name for Diehard, by the way.
Good luck on finding a suitable replacement battery for your 2004 PT Cruiser Platinum.
Nov 18, 2010 | 2004 Chrysler PT Cruiser
Health & Beauty Logo
26 people viewed this question
Top Sonicare Health & Beauty Experts
Are you a Sonicare Health and Beauty Expert? Answer questions, earn points and help others
