Question about Miscellaneous
I need the torque settings for head bolts for the intek 17.0 hp ohv riding mower. some numbers i have are as follows.
Numbers are 31F7070112E1, 030729ZE30425, BG20249, GXL100A080493
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 34 Answers
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
SOURCE: NEED WIRING DIAGRAM FOR MTD 14.5 HP OHV I/C RIDING MOWER
try going to www.tulsaenginewarehouse.com/drawings/allwiring.pdf
Posted on Aug 29, 2009
  • 61 Answers
SOURCE: Craftsman Ride-on hard start, loss of power
you have to get piston to top dead center, there should be 4 thousandths of clearance between rocker and valve on both valves.
use two wrenches to tighen
Posted on Sep 06, 2009
Testimonial: "good advice..thanks!"
  • 623 Answers
SOURCE: what type of oil do i use in my briggs stratton
You should be safe with a 10w-30 weight any major brand oil.
Posted on Jun 21, 2010
  • 6468 Answers
SOURCE: what is the valve adjustment?
its the clearance between the rocker arm and the valve on briggs engines i set them to .006
Posted on May 06, 2012
How do I remove the horizontal shaft
the motor you are working on has a split block and you have to take the motor off and remove the bolts holding the two halves of the block apart. this motor doesn't have a separate removable head. it is cast as two pieces and in my opinion makes more work for some repairs. hope this helps
Oct 13, 2015 | Briggs AND Stratton Intek Briggs &...
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
Tightening sequence for briggs and stratton 17.5 hp engine
tighten bolts opisite of each other snug then one 1/4 turn to tork
Oct 06, 2014 | Briggs AND Stratton Intek Briggs &...
What is the valve setting for 2004 18.5 HP briggs & stration intek ohv engine?
31C700 engine? (model number)
This is pretty generac for all of their engines as a general rule 0.004 - 0.006
From the service manual for the 31C700 engine:
ADJUST VALVES
1. Set No. 1 cylinder at 1/4" (6.4mm) past TDC, compression
stroke.
a. Adjust valves and check, Fig. 17.
Valve Clearance (cold) IN and EX .005" (0.13 mm)
b. Torque adjusting screws and jam nuts to 60 in. lbs.
(7.0 Nm).
2. Set No. 2 cylinder at TDC, compression stroke.
a. Repeat for No. 2 cylinder.
Thanks for choosing FixYa,
Kelly
Aug 24, 2011 | Craftsman Garden
I need torque settings for the engine ie head bolts v6 engine 1
i am replacing the heads on a GMC 350 cu in engine. what is the final torque of the head bolts?
Jul 15, 2010 | 1985 Chevrolet Camaro
Sep 02, 2009 | Craftsman Garden
18.5 B&S Intek single head OHV will 15 horse head fit ?
The valves on the bigger engine, will be larger.
Therefore changing the head off the smaller engine, may cause minor aspiration problems.
But if it's an 'OLD' engine, it probably won't care.
Off you go.
Good luck with that.
Jul 27, 2009 | Garden
Need head bolt torque for Brigges Stratton 18 Hp
Jul 10, 2009 | Garden
Miscellaneous Logo
78 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
