Question about Car Audio & Video
What should pwr ant knob be adjusted to? - Car Audio & Video
  • Chris McDonald
    Chris McDonald Apr 22, 2017
    Radio is a magnum s6
  • Car Audio & ... Master
  • 5,670 Answers
The PWR/AMT knob:
PWR: Variable RF Output Power. The transmitted power of the Magnum S-6 may be varied from 0 to 40 watts peak in all modes. Rotate clockwise to increase RF output power. Rotate counterclockwise to decrease RF output power.
AMT: All Mode Talk Back. AMT, a Magnum exclusive, is an independent talk back monitor. The AMT functions in all modes and allows the operator to monitor the trans- mitted audio of the Magnum S-6. To increase the vol- ume of the talk back rotate the control clockwise. To decrease rotate counterclockwise. To turn off the talk back rotate the control completely counterclockwise.
Posted on Apr 25, 2017
How to use and operate a uniden PC76XL CB radio with description and explanation of knobs and controls
wow this ones an oldie !! I had to go out back and look at my ole 88 transtar dumper !! !! to get enough to answer this one ~~~ well starting from right to left , Volume = well that ones self explaining ~~ next ones squelch ~~ this one adjusts the noise canceling ~ the next knob is mic gain = this one might be a bit tricky ~~~ if your runnin a pwr mic already lots of folks modiflyed this knob to adjust the depth of echo !!! with echo installed but if no pwr mic this one can adjust your modulation strength!! the next knob is delta tune !! this knob lets you use sideband , although the laws have changed now!! since this thing was made !!! id keep that one in the middle so not to draw any unwanted attention from officials ~~ the next one is rf gain !!! this one lets you get a sort of private channel between your buddy and you in the truck in front of you , this one id keep right full !!! and the last one is of course channel !! this one lets you set what channel you want to operate on !! now all you need is a good antenna (don't forget to ground it too truck frame !!!) and of course 12 volt power !! use a rfi filter if you don't have a diesel under the hood ~~~ or your gonna hear lots of noise !! and your ready to go !!!
Nov 14, 2016 | Uniden Radio Communications
2004 Saturn 5spd wont start cant pop clutch to start and now coolant and pwr str light flashing on dash
Try adding water absorb ant fluidd, ie heat. To fuel. May have condensed water in tank. Popped a fuse or breaker
Dec 26, 2017 | Cars & Trucks
99Nissan Altima. power ant blue wire does not work antenna.
The blue pwr ant wire on most Kenwoods is non-functional even though it is present in the harness and on the wiring diagram. Use the blue/white rem pwr wire.
Jan 06, 2014 | Kenwood KDC-HD455U
Low pwr on xmit,weak rec,swr alert lite on xmit swr 1:4-1 on ch 20
you have no power because your radio is not tuned to your antenna.You get a new radio and put junky coax and a decent antenna and you expect it to work right. Get 75 ft of rg-213 and you will see a change.
Jan 08, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
My ANT light comes on when ever i push the mic button but my SWR isnt that high
The meter will be more accurate and an external meter will be even better. If they show good disregard the ant light it is adjustable. It may have been set to sensitive from factory. These erroneous SWR reading can be the side effects of a PEAK & TUNE if the coils have been spread but that should also show on meter.
SWR meter calibrations
  • Switch (S/RF SWR CAL) to the CAL position.
  • Push and hold mic button
  • While holding mic button adjust the SWR CAL knob so the meter needle swings to the CAL mark on the meter
  • While still holding down the mic button, set the (S/RF SWR CAL) switch to the SWR position, to read the SWR reading. Note: When switched to SWR position the meter needle should ideally be as far to the left as possible. Anything over 3 is not acceptable.
Jul 28, 2011 | Cobra 29 LTD CB Radio
Need to know what the four plug in wires hook up to got 2 black wires, a blue wire and a yellow wire
2 black are normally grounds
blue is remote or pwr ant
yellow is either your acc wire or constant pwr...(acc being switched power)
Mar 21, 2011 | Car Audio & Video
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 with bluetooth setup troubles
Mar 02, 2009 | Kenwood KVT-512 Car DVD Player
Bypass parking brake for dvd player Kenwood kvt 512
Just connect the purple safety wire to the car's ground location or to the other ground wires.
Dec 25, 2008 | Kenwood KVT-512 Car DVD Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
