Question about Euro-Pro Irons
I have a Euro-Pro 8001 iron the gasket that goes around the cap where would I put water in has faded away need a replacement how do I purchase one
    Master:
  • 604 Answers
Go to a hardware store and show them,they will have one
Posted on Apr 22, 2017
SOURCE: Manual for Euro-Pro G6118H
I don't know if you have the number for the euro pro customer service department; but, I had the same problem, called customer service, and had a manual emailed to me. The manual came within a couple of hours via email. In case you don't have the number and still need a manual for your unit, try calling 800.798.7398. I hope this helps and good luck!
Posted on Jul 18, 2008
  • 19 Answers
SOURCE: shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Posted on Aug 16, 2009
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Posted on Jan 05, 2010
heatman101
  • 43501 Answers
SOURCE: Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
ercupa190
  • 12223 Answers
SOURCE: REPLACEMENT COVER FOR EURO PRO IRONING BOARD -WEDGE
you must contact your supplier vendor of iron in order to get the parts. or search in internet by Marconny appliance.
God bless you
Posted on Jul 23, 2012
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
My Shark Auto-Shutoff, X-tended Steam Burst, goes into the auto-shut off after only one or two pieces are done. The only way to power it back up seems to be to unplug it and start over. Suggestions?
Mine does the same thing and it is fairly new. I think i will purchase another brand and put this one away for emergencies only. I no longer have the manual.
Mar 31, 2010 | Euro-Pro Shark GI490 Iron
Hi, I have been given a Euro-Pro Ironing Solution EP1005 without a manual where do I put water in for steam & how does the suction work Marj
I don't know that system, but you're real lucky, that type of irons are fantastic! Most such have something that looks like a big black knob (you can see the same type e.g. on steam cleaners). You screw it counter-clockwise until it opens. Then you fill it up with water through the little hole. That type of valve is the one I have seen the most on pro systems, while my own home type generator iron only has a tank you simply pull off so you can fill it under the faucet. I have no idea how the suction works, except for it being real great as it helps draw the steam through the garment and away, so it gets dry instantly. I'm sure it also allows you to use a lot more steam, e.g. on tough wrinkles...
Why don't you go to the Euro-Pro website, mail them and ask for their help in getting a manual for it? Or maybe you already tried that? If you look around, you might be able to get a downloadable manual from one of the many manual sellers online...
Oct 27, 2009 | Euro-Pro EP1005 Iron
Euro Pro Shark Iron
Thank you for taking the time to warn us and others about the euro pro shark iron. I will help spread the word.
Aug 10, 2009 | Irons
Euro Pro Steam Iron
I'm having a problem with a Euro Pro Steam Iron as well. Thier customer service phone number is 1-800-798-7398. Hope this helps
May 13, 2009 | Euro-Pro Steam Generator EP8001 Iron
EuroPro Steamiron
I need to find parts for the europro ep 8001
Sep 28, 2008 | Euro-Pro Steam Generator EP8001 Iron
Handle on iron gets too hot to hold onto. Product is an Euro-Pro Ironing Solution. Ironing system includes the iron and ironing board together.
I purchased a silicone heat protector for a pot handle and sewed it together with dental floss around the iron handle
Sep 23, 2008 | Euro-Pro EP1005 Iron
Euro Pro Steam Generator EP8001 Iron - manual needed
Contacted Shark customer service and they emailed one. My product was the EP 8000 which is no longer produced. Sent the revised manual that is only a bit different for the EP 8001. Call them, they are very nice.
Jun 19, 2008 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
154 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
