Question about GE Microwave Ovens
Main refrigerator door hinge close mechanism broken....the door must be fully closed manually.
GE model Z1ss420DMBS
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Posted on Nov 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: the GE Spacemaker model JVM1440WH04
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 08, 2008
  • 52 Answers
SOURCE: Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 26, 2009
  • 3 Answers
SOURCE: Door won't stay closed
I just had this issue happen to me last week.. fortunately I was standing in my kitchen when it happened... I heard a snap and then a piece fall down the inside of either the door or the front key panel.. I'm assuming this controlled the door locking/oven turning on safety mechanism. The inside light wont go off and it won't turn on to cook.. I am trying to figure out if it's worth paying to fix or just replace the whole unit!? Anyone know if this is fixable by oneself rather than spend a bunch of money on a service technician??
Posted on Mar 03, 2011
  • 65 Answers
SOURCE: GE microwave oven model#JVM1441BH04 when
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Posted on Sep 29, 2011
Fix my ge spacemaker microwave door from wiggling at the door hinges (not the latches)?
http://youtu.be/nIdT4kS3noY This link will show you how to gain access to the problem. Sounds like a lose screw or two
Jan 03, 2015 | GE Microwave Ovens
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Sharp Microwave Carousel R-420B. I put a bowl of soup in , closed the door, pressed Minute Plus, and hit Stop with approx 20 seconds to go... pressed the door release but nothing happened... door...
Usually, the door lever or hinges is the cause of this type of problem.
But in this case, I don't think the door lever or hinge is the cause of your problem.
I think the door is jammed and only needs some force before is can open or unjam.
Use your hands or a flat Philips screw driver to forcefully open the door. Don't apply too much force. Just apply a reason amount of force that could open the oven door.
Before you attempt to forcefully open the microwave door, leave it for about 45mins to 1hr, after that forcefully open the door.
If the above doesn't help to open the door, please let me know so that I can direct you further.
I wish you good luck.
Regards.
Mine does this occasionally, and it's because the door hinges have got a bit out of line, allowing the door to drop slightly, so the catch mechanism won't quite disengage.
Look along the bottom edge of the door and see if it has dropped lower than the front panel next to it. Try applying a bit of upward pressure on the bottom edge with your fingers, while pulling towards you at the same time, and with your other hand press the release button.
If that gets it open, remove last night's failed meal, open the door fully and carefully force it up a bit at a time, to bend the hinges back to level - keep pushing the door back so it nearly closes, and look at the bottom edge to check on progress. When the bottom of the door looks level with the panel , try closing it fully and see if the release button will open it again.
Jun 03, 2011 | Sharp R420L Microwave Oven
I have a built in Whirlpool oven (RS696PXGB7). The door almost closes but does not have a secure seal and the light doesn't go off. It seems as if the hidges are too weak to close it all the way. Is...
HI U WILL HAVE A CLIP ON EACH HINGE .... PULL CLIP FULLY OPEN ...SLOWLY CLOSE THE DOOR ..IT WILL COME OFF THE INNER HINGE ... RESIT BACK IN AND DO DLIPS BACK UP.. TRY DOOR SLOWLY INCASE YOU HAVE NOT SAT THE HINGE BACK ON RIGHT ,,, THIS WILL CORRECT THE PROBLEM. CROSS FINGERS ... JUST KEEP TRYING U WILL DO IT.
Feb 27, 2011 | Microwave Ovens
The oven is saying "close
one of the microswitch that senses the door is closed is deffective or it could be missalinged, it could also be a broken plastic pin (on the door) that pushes on the switch, jus be careful when playing with those switches there could be as many as 4 all around the door and one of them is a safety switch that SHORTS the main electrical feed, so that the fuse burns if one of the other switches fails, you really do NOT WANT TO OPEN THE DOOR WHEN THE OVEN IS FONCTIONING)
Hope this helps!
Jan 31, 2011 | Microwave Ovens
I have a sharp carousel model r-305m . we cannot close our door without slamming it. it looks like the top catch has broken or slipped down. can you help us
Door catches.
If one of the latches has broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Door switches
If one of the door interlock switches is not switching properly, that can cause the turntable/light to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Jan 12, 2011 | Sharp Microwave Ovens
The door closes but not firmly their is still movement when fully closed
The door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Dec 30, 2010 | Panasonic NN-T551 Microwave Oven
We have a 10 yr old GE Advantium SCA2000. The door appears to be loose at the hinge. When closed the door slightly drops down just enough for the oven not to start or once running it will stop. How can...
Here's the full service manual with installation instructions.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You may also need to see this file on door switch checking.
Aug 21, 2010 | Microwave Ovens
Microwave oven, ge profile model #pvm1870 the light stays on when the door is closed. microwave makes a noise while the light stays on. slight pressure to the door turns the light off.
This is usually caused by either a bad door switch, a loose door switch mount, or bad door hinge alignment.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Microwave Ovens
Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Nov 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
