Do i need to call a technician to fix this problem? The bottom oven works fine but th top one stopped heating. We recently used to self cleaning option; does this have something to do with it? We follow the instruction to a T...can someone help?
I have the exact same problem with an ECS230 and it also occurred after self-cleaning. The unit has 3 elements, none of which are heating up making the element suggestion unlikely. It also seems that i cannot change the time setting.
The high limit switch has tripped on this unit. Remove the vent panel behind the door and there will be a button in there behind the wires. Press this button with the circuit breaker turned off and that will rectify the problem. You still might need a servicer out to take a look at the unit though
Was this solution helpful? Show your Appreciation by rating it:
