Question about Hotpoint Washing Machines
Hotpoint aquarius WF720 has stopped and is flashing H20
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
  • 193 Answers
SOURCE: h20 error on hotpoint
Lift the lid and check that clear hose is connected to the pressure switch.
Posted on Nov 02, 2009
SOURCE: Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Posted on Feb 08, 2010
  • 15 Answers
SOURCE: Hotpoint Aquarius FDW60 Machine stops halfway
This sounds like the heater is not energising usually means the heater has failedalthough a blocked or sticking pressure switch will cause the same problem
Posted on Apr 30, 2010
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
H20 is flashing on my hotpoint washing machine
H20 indicates a problem with water supply.
Check the inlet hose/s for blockage or restriction, make sure the water supply is o/k, and the pressure is good, also check the inlet valve/s filters.
Apr 02, 2011 | Hotpoint Aquarius WD640 Front Load...
My machine is flashing h20 and wont start why
hi my machine is flashing h20 what does it mean
Mar 26, 2011 | Hotpoint Aquarius WD640 Front Load...
H20 indicates a water supply problem.
Could be frozen pipe, check the hose/s for kinks or restriction, and that you are getting water at the inlet valve/s, and that the water pressure is o/k
Dec 18, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Jan 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Spinning then stoping, spinning then stoping. lights flashing on and off and flashing code f 12 now just turned off. hotpoint wf720
firstly i would check motor brushes as this can sometimes happen when they are needing replaced, remember to unplug the machine first.
Jul 25, 2008 | Hotpoint Washing Machines
H20 error messages
h20 is normally a water valve problem please check these regards jason
Jun 09, 2008 | Hotpoint Aquarius WD640 Front Load...
H20 errors on Hotpoint WD640
this is normally a water valve problem
Washing Machines Logo
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
